Datasheet Texas Instruments CD54AC283F3A — Даташит
Серия | CD54AC283 |
Модель | CD54AC283F3A |
4-битный двоичный полный сумматор с быстрым переносом 16-CDIP от -55 до 125
4-Bit Binary Fill Adder With Fast Carry datasheet
PDF, 436 Кб, Версия: D, Файл опубликован: 17 май 2000
![]() 8 предложений от 8 поставщиков Микросхема Счётчик, Binary Full Adder Single 4Bit 16Pin CDIP Tube | |||
CD54AC283F3A Texas Instruments | 3 749 ₽ | ||
CD54AC283F3A Texas Instruments | 5 329 ₽ | ||
CD54AC283F3A | по запросу | ||
CD54AC283F3A Texas Instruments | по запросу |
Pin | 16 |
Package Type | J |
Industry STD Term | CDIP |
JEDEC Code | R-GDIP-T |
Package QTY | 1 |
Carrier | TUBE |
Маркировка | CD54AC283F3A |
Width (мм) | 6.92 |
Length (мм) | 19.56 |
Thickness (мм) | 4.57 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Bits | 4 |
F @ Nom Voltage(Max) | 100 Mhz |
Function | Arithmetic |
ICC @ Nom Voltage(Max) | 0.08 мА |
Output Drive (IOL/IOH)(Max) | 75/-75 мА |
Package Group | CDIP |
Package Size: mm2:W x L | See datasheet (CDIP) PKG |
Rating | Military |
Schmitt Trigger | No |
Technology Family | AC |
Тип | Binary |
VCC(Max) | 5.5 В |
VCC(Min) | 1.5 В |
Voltage(Nom) | 3.3,5 В |
tpd @ Nom Voltage(Max) | 16 нс |
RoHS | See ti.com |
- CMOS Power Consumption and CPD Calculation (Rev. B)PDF, 89 Кб, Версия: B, Файл опубликован: 1 июн 1997
Reduction of power consumption makes a device more reliable. The need for devices that consume a minimum amount of power was a major driving force behind the development of CMOS technologies. As a result CMOS devices are best known for low power consumption. However for minimizing the power requirements of a board or a system simply knowing that CMOS devices may use less power than equivale - Input and Output Characteristics of Digital Integrated CircuitsPDF, 1.7 Мб, Файл опубликован: 1 окт 1996
This report contains a comprehensive collection of the input and output characteristic curves of typical integrated circuits from various logic families. These curves go beyond the information given in data sheets by providing additional details regarding the characteristics of the components. This knowledge is particularly useful when for example a decision must be made as to which circuit shou - Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Data sheets which usually give information on device behavior only under recommended operating conditions may only partially answer engineering questions that arise during the development of systems using logic devices. However information is frequently needed regarding the behavior of the device outside the conditions in the data sheet. Such questions might be:?How does a bus driver behave w - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Серия: CD54AC283 (1)
- CD54AC283F3A
- Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Counter/Arithmetic/Parity Function Products
