Datasheet Texas Instruments UC2901DG4 — Даташит
| Серия | UC2901 |
| Модель | UC2901DG4 |
Изолированный генератор обратной связи 14-SOIC от -40 до 85
Isolated Feedback Generator datasheet
PDF, 593 Кб, Версия: A, Файл опубликован: 13 янв 2010
Купить UC2901DG4 на РадиоЛоцман.Цены — от 203 до 625 ₽13 предложений от 13 поставщиков Микросхема Чип управления батареи, Isolated Feedback Generator 14-SOIC -40℃ to 85℃ | |||
| UC2901DG4 Texas Instruments | 625 ₽ | ||
| UC2901DG4 Texas Instruments | по запросу | ||
| Pin | 14 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 50 |
| Carrier | TUBE |
| Маркировка | UC2901D |
| Width (мм) | 3.91 |
| Length (мм) | 8.65 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Control Method | Amplitude modulation |
| Duty Cycle(Max) | 50 % |
| Frequency(Max) | 5000 kHz |
| Package Group | SOIC |
| Package Size: mm2:W x L | 14SOIC: 52 mm2: 6 x 8.65(SOIC) PKG |
| Rating | Catalog |
| Special Features | AM system for isolated feedback error signal,1% reference,Synchronizable |
| Topology | N/A |
| UVLO Thresholds On/Off | 3.9 В |
| Vin(Max) | 40 В |
| Vin(Min) | 4.5 В |
- The UC1901 Simplifies the Problem of Isolated Feedback in Switching RegulatorsPDF, 329 Кб, Файл опубликован: 5 сен 1999
The UC 1901 isolated feedback generator solves many of the problems associated with closing a feedback control loop across a voltage isolation boundary. As a stable and reliable alternative to an optical coupler these devices feature an amplitude modulation system that allows a loop error signal to be coupled with a small R. F. transformer or capacitor. This application note discusses the functi - DN-19 A Simple Isolation Amplifier Using the UC1901PDF, 112 Кб, Файл опубликован: 5 сен 1999
The UC1901 Isolated Feedback Generator has other applications besides providing isolated feedback in switching power supplies. This IC's amplitude modulation system and error amplifier can implement an isolation amplifier characterized by (1) good signal linearity (2) wide bandwidth (3) high isolation capability and (4) low cost. Isolation amplifiers of this type are in switching power supplies - DN-33 Optocoupler Feedback Drive Techniques Using the UC3901 and UC3903PDF, 45 Кб, Файл опубликован: 5 сен 1999
A variety of low-cost supervisory ICs contain the required building blocks for the more demanding optocoupler feedback drive applications. Initially developed to address other specific power supply tasks several control ICs excel in the role as precision optocoupler control and drivers. This design note describes a basic optocoupler driver circuit and also a more advanced optocoupler drive circ
Серия: UC2901 (8)
- Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
