Линейка продуктов KEEN SIDE
Datasheet Texas Instruments ADS574KU-2 — Даташит
СерияADS574
МодельADS574KU-2
Микропроцессорный КМОП аналого-цифровой преобразователь 28-SOIC
Pin28
Package TypeDW
Width (мм)7.5
Length (мм)17.9
Thickness (мм)2.35
Max Height (мм)2.65
Рекомендуемая замена
ReplacementADS574KP
Replacement CodeS
RoHSНе совместим
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • CDAC Architecture Gives ADC574 Pinout /Sampling, Low Power, New Input Ranges
    PDF, 54 Кб, Файл опубликован: 27 сен 2000
    This application note compares basic current-mode successive approximation A/Ds with CDAC-based architectures, and shows how adding a resistor divider network to the CDAC input permits the Burr-Brown ADS574 and ADS774 to fit existing ADC574 sockets. It then goes on to descibe some new analog input voltage ranges available on these parts due to the resistor network and CDAC approach.
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Interleaving Analog-to-Digital Converters
    PDF, 64 Кб, Файл опубликован: 2 окт 2000
    It is tempting when pushing the limits of analog-to-digital conversion to consider interleaving two or more converters to increase the sample rate. However, such designs must take into consideration several possible sources of error.
  • Complete Temp Data Acquisition System From a Single +5V Supply
    PDF, 68 Кб, Файл опубликован: 2 окт 2000
    The CMOS ADS574 and ADS774 are drop-in replacements for industry standard ADC574 analog-to-digital converter, offering lower power and the capability to operate from a single +5V supply. The switched capacitor array architecture (CDAC), with the input resistor divider network to provide ADC574 input ranges, also allow the new parts to handle additional input ranges, including a 0V to 5V range. Thi
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • What Designers Should Know About Data Converter Drift
    PDF, 95 Кб, Файл опубликован: 2 окт 2000
    Exactly how inaccurate will a change in temperature make an analog-to-digital or digital-to-analog converter? As designers are well aware, a 12-bit device may provide a much lower accuracy at its operating-temperature extremes, perhaps only to 9 or even 8 bits. But for lack of more precise knowledge, many play it safe (and expensive) and overspecify.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
  • Semiconductors > Data Converters > Analog to Digital Converter > Precision ADC (<=10MSPS)
ADS574KU2, ADS574KU 2
На английском языке: Datasheet Texas Instruments ADS574KU-2
