Datasheet Texas Instruments UCC35701QTR — Даташит
СерияUCC35701
МодельUCC35701QTR
Advanced Voltage Mode Pulse Width Modulator datasheet
PDF, 984 Кб, Версия: C, Файл опубликован: 17 июн 2005
Pin20
Package TypeUTR
Approx. Price (US$)2.95 | 1ku
Control MethodFeedforward
Voltage
Duty Cycle(Max)(%)99
Frequency(Max)(kHz)700
Gate Drive(Typ)(A)1
PDIP
TSSOP
Special FeaturesMulti-topology
Soft Start
Synchronization Pin
TopologyBoost
Buck
Flyback
Forward
UVLO Thresholds On/Off(V)13/9
Vin(Max)(V)15
Vin(Min)(V)9
RoHSНе совместим
  • U-150 Applying the UCC3570 Voltage-Mode PWM Controller to Both Off-Line
    PDF, 568 Кб, Файл опубликован: 5 сен 1999
    The UCC3570 families of pulse-width modulators are for application in isolated switching supplies using primary-side control and a voltage-mode feedback loop. BiCMOS processing provides higher switching frequencies at lower quiescent current drain, while including innovations in both performance and protection features. Its versatility is demonstrated with the description of a 50W, wide input-volt
  • DN-62 Switching Power Supply Topology Voltage Mode vs. Current Mode
    PDF, 66 Кб, Файл опубликован: 5 сен 1999
    This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UCC35701QTR
