Datasheet Texas Instruments SN74HC393NSRE4 — Даташит
| Серия | SN74HC393 |
| Модель | SN74HC393NSRE4 |
Двойные 4-битные двоичные счетчики 14-SO от -40 до 85
SN54HC393, SN74HC393 datasheet
PDF, 1.2 Мб, Версия: D, Файл опубликован: 28 июл 2003
Купить SN74HC393NSRE4 на РадиоЛоцман.Цены — от 11 до 14 ₽7 предложений от 7 поставщиков Микросхема Логический контроллер, Counter/Divider Dual 4Bit Binary UP 14Pin SOP T/R | |||
| SN74HC393NSRE4 Texas Instruments | 11 ₽ | ||
| SN74HC393NSRE4 Texas Instruments | 14 ₽ | ||
| SN74HC393NSRE4 Texas Instruments | по запросу | ||
| Pin | 14 |
| Package Type | NS |
| Industry STD Term | SOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | HC393 |
| Width (мм) | 5.3 |
| Length (мм) | 10.3 |
| Thickness (мм) | 1.95 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2 |
| Mechanical Data | Скачать |
| Bits | 4 |
| F @ Nom Voltage(Max) | 28 Mhz |
| Function | Counter |
| ICC @ Nom Voltage(Max) | 0.08 мА |
| Output Drive (IOL/IOH)(Max) | 5.2/-5.2 мА |
| Package Group | SO |
| Package Size: mm2:W x L | 14SO: 80 mm2: 7.8 x 10.2(SO) PKG |
| Rating | Catalog |
| Technology Family | HC |
| Тип | Binary |
| VCC(Max) | 6 В |
| VCC(Min) | 2 В |
| Voltage(Nom) | 3.3,5 В |
| tpd @ Nom Voltage(Max) | 62 нс |
- HCMOS Design Considerations (Rev. A)PDF, 207 Кб, Версия: A, Файл опубликован: 9 сен 2002
This document describes a potential problem designers may encounter when using high-speed CMOS (HC) logic devices. There also is a broad range of CMOS-system to non-CMOS-system interfaces that need to be considered. The design engineer inevitably encounters these interfaces. Key considerations for handling these interfaces are also discussed in this book.
Серия: SN74HC393 (19)
- Semiconductors > Logic > Specialty Logic > Counter/Arithmetic/Parity Function
