Datasheet Texas Instruments SN74LVTH244ARGYR — Даташит
СерияSN74LVTH244A
МодельSN74LVTH244ARGYR
Восьмеричные буферы/драйверы ABT 3,3 В с выходами с 3 состояниями 20-VQFN от -40 до 85
SN54LVTH244A, SN74LVTH244A datasheet
PDF, 1.5 Мб, Версия: J, Файл опубликован: 8 окт 2003
Pin20
Package TypeRGY
Industry STD TermVQFN
JEDEC CodeR-PQFP-N
Package QTY3000
МаркировкаLXH244A
Width (мм)3.5
Length (мм)4.5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Bits8
F @ Nom Voltage(Max)160 Mhz
ICC @ Nom Voltage(Max)0.005 мА
Output Drive (IOL/IOH)(Max)-32/64 мА
Package GroupVQFN
Package Size: mm2:W x L20VQFN: 16 mm2: 3.5 x 4.5(VQFN) PKG
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)3.5 нс
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
На английском языке: Datasheet Texas Instruments SN74LVTH244ARGYR
