Datasheet Texas Instruments SN74LVC02ANSRE4 — Даташит
| Серия | SN74LVC02A |
| Модель | SN74LVC02ANSRE4 |
Четверной 2-входовой элемент положительного ИЛИ-НЕ 14-SO от -40 до 125
SN54LVC02A, SN74LVC02A datasheet
PDF, 1.3 Мб, Версия: Q, Файл опубликован: 26 июл 2005
Купить SN74LVC02ANSRE4 на РадиоЛоцман.Цены — от 3.10 до 9.67 ₽7 предложений от 7 поставщиков Микросхема Логический чип, NOR Gate 4Element 2IN CMOS 14Pin SOP T/R | |||
| SN74LVC02ANSRE4 Texas Instruments | 3.10 ₽ | ||
| SN74LVC02ANSRE4 Texas Instruments | 7.83 ₽ | ||
| SN74LVC02ANSRE4 Texas Instruments | 9.67 ₽ | ||
| SN74LVC02ANSRE4 | по запросу | ||
| Pin | 14 |
| Package Type | NS |
| Industry STD Term | SOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | LVC02A |
| Width (мм) | 5.3 |
| Length (мм) | 10.3 |
| Thickness (мм) | 1.95 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2 |
| Mechanical Data | Скачать |
| Bits | 4 |
| F @ Nom Voltage(Max) | 70 Mhz |
| ICC @ Nom Voltage(Max) | 0.04 мА |
| Output Drive (IOL/IOH)(Max) | 24/-24 мА |
| Package Group | SO |
| Package Size: mm2:W x L | 14SO: 80 mm2: 7.8 x 10.2(SO) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | LVC |
| VCC(Max) | 3.6 В |
| VCC(Min) | 1.5 В |
| Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
| tpd @ Nom Voltage(Max) | 8.9,7.4,5.4,4.4 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly - Power-Up 3-State (PU3S) Circuits in TI Standard Logic DevicesPDF, 209 Кб, Файл опубликован: 10 май 2002
Серия: SN74LVC02A (18)
- Semiconductors > Logic > Gate > NOR Gate
