Datasheet Texas Instruments LMH6554LEE/NOPB — Даташит
Серия | LMH6554 |
Модель | LMH6554LEE/NOPB |
Ультралинейный полностью дифференциальный усилитель 2,8 ГГц 14-UQFN от -40 до 125
LMH6554 2.8-GHz Ultra Linear Fully Differential Amplifier datasheet
PDF, 1.7 Мб, Версия: P, Файл опубликован: 14 янв 2015
Pin | 14 |
Package Type | NHJ |
Industry STD Term | UQFN |
JEDEC Code | S-PQFP-N |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | AJA |
Width (мм) | 2.5 |
Length (мм) | 2.5 |
Thickness (мм) | .6 |
Pitch (мм) | .4 |
Max Height (мм) | .6 |
Mechanical Data | Скачать |
2nd Harmonic | 68 dBc |
3rd Harmonic | 70 dBc |
@ MHz | 250 |
Acl, min spec gain | 1 V/V |
Additional Features | Shutdown |
Архитектура | Bipolar,Current FB,Fully Differential |
BW @ Acl | 2800 МГц |
CMRR(Min) | 73 дБ |
CMRR(Typ) | 83 дБ |
GBW(Typ) | 2500 МГц |
Input Bias Current(Max) | 8000000 pA |
Iq per channel(Max) | 52 мА |
Iq per channel(Typ) | 52 мА |
Количество каналов | 1 |
Output Current(Typ) | 150 мА |
Package Group | UQFN |
Package Size: mm2:W x L | 14UQFN: 6 mm2: 2.5 x 2.5(UQFN) PKG |
Rail-to-Rail | No |
Rating | Catalog |
Slew Rate(Typ) | 6200 V/us |
Total Supply Voltage(Max) | 5.25 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 4.7 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 0.9 нВ/rtГц |
Vn at Flatband(Typ) | 0.9 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 3 мВ |
- Evaluation Modules & Boards: LMH6554LE-EVAL
Evaluation board for the LMH6554
- A Walk Along the Signal Path (High-Speed Signal Path)PDF, 461 Кб, Файл опубликован: 30 мар 2005
- Using High Speed Diff Amp to Drive ADCs (Rev. A)PDF, 175 Кб, Версия: A, Файл опубликован: 26 апр 2013
The right high speed differential amplifier will add flexibility to signal chains that include a high speedanalog-to-digital converter (ADC). A differential amplifier can provide signal conditioning such as singleended to differential conversion, impedance transformation, and gain or attenuation. - AN-2177 Using the LMH6554 as a ADC Driver (Rev. A)PDF, 1.7 Мб, Версия: A, Файл опубликован: 26 апр 2013
This application report discusses the use of the Texas Instruments LMH6554 as an ADC driver. - AN-1719 Noise Figure Analysis Fully Differential Amplifier (Rev. A)PDF, 97 Кб, Версия: A, Файл опубликован: 1 май 2013
This application note provides noise figure analysis for fully differential amplifiers, including output noisecalculation and noise figure calculation. - Converting single-ended video to differential video in single-supply systemsPDF, 212 Кб, Файл опубликован: 16 сен 2011
Серия: LMH6554 (3)
- LMH6554LE/NOPB LMH6554LEE/NOPB LMH6554LEX/NOPB
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > High-Speed Op Amps (>=50MHz)
