Datasheet ТI TPS54380PWPRG4 — Даташит
| Серия | TPS54380 |
| Модель | TPS54380PWPRG4 |
Входное напряжение от 3 В до 6 В, синхронный понижающий преобразователь 3 А для секвенирования 20-HTSSOP от -40 до 85
3-V to 6-V Input 3-A Output Tracking Synchronous Buck PWM Switcher datasheet
PDF, 780 Кб, Версия: B, Файл опубликован: 11 фев 2005
- Using TPS54x80 Tracking SWIFT(TM) dc/dc Converters f/Simult. Tkg of Input SupplyPDF, 115 Кб, Файл опубликован: 10 фев 2005
High-performance signal processing devices, such as FPGAs and DSPs, require multiple power supply voltages for operation. The order and timing in which these supply outputs power up and down is usually specified. A design example using the TPS54380 is shown for the case where the power supply to be tracked is also the input voltage to the TPS54380. Information is provided for adjusting the start-u - Sequencing with TPS54x80 and TPS54x73 DC/DC ConvertersPDF, 169 Кб, Файл опубликован: 14 апр 2003
Design of a power supply for a high-performance point-of-load processor requires special attention to manage core and input/output (I/O) voltage sequencing, which is critical to device operation and long term reliability. The TPS54x80 devices of low input voltage synchronous-buck dc/dc converters are designed for easily implementing sequential, ratio-metric, or simultaneous sequencing schemes. F
Серия: TPS54380 (4)
- TPS54380PWP TPS54380PWPG4 TPS54380PWPR TPS54380PWPRG4
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Converter (Integrated Switch)
