Datasheet Texas Instruments OPA544T-1 — Даташит
СерияOPA544
МодельOPA544T-1
Высоковольтный сильноточный операционный усилитель 5-TO-220
High-Voltage, High-Current Operational Amplifier datasheet
PDF, 883 Кб, Файл опубликован: 27 сен 2000
Pin5
Package TypeKC
Industry STD TermTO-220
JEDEC CodeR-PSFM-T
Width (мм)8.51
Length (мм)10.16
Thickness (мм)4.58
Pitch (мм)1.7
Max Height (мм)4.7
Рекомендуемая замена
ReplacementOPA544T
Replacement CodeS
Additional FeaturesN/A
Approx. Price (US$)9.09 | 1ku
АрхитектураFET
CMRR(Min)(dB)90
CMRR(Typ)(dB)106
GBW(Typ)(MHz)1.4
Input Bias Current(Max)(pA)100
Iq per channel(Max)(mA)15
Iq per channel(Typ)(mA)12
Number of Channels(#)1
Offset Drift(Typ)(uV/C)10
Operating Temperature Range(C)-40 to 85
Output Current(Typ)(mA)4000
Package GroupTO-220
Package Size: mm2:W x L (PKG)See datasheet (TO-220)
Rail-to-RailNo
Slew Rate(Typ)(V/us)8
Total Supply Voltage(Max)(+5V=5, +/-5V=10)70
Total Supply Voltage(Min)(+5V=5, +/-5V=10)20
Vos (Offset Voltage @ 25C)(Max)(mV)5
RoHSНе совместим
  • Evaluation Modules & Boards: OPAMPEVM
    Universal Operational Amplifier Evaluation Module
  • Power Amplifier Stress and Power Handling Limitations
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    To achieve reliable power amplifier designs you must consider the stress on the amplifier compared to its power handling limitations. Power handling limits are specified by the Safe Operating Area (SOA) curves of the power amp. Stress on the amplifier depends on amplifier load and signal conditions which can be evaluated with straightforward techniques.
  • Building your own Battery Simulator
    PDF, 114 Кб, Файл опубликован: 14 окт 2013
    Building your own Battery Simulator OPA544, bq2409x, bq2404x, bq2415x, bq2425x, bq2416x
  • DC MOTOR SPEED CONTROLLER: Control a DC Motor without Tachometer Feedback
    PDF, 50 Кб, Файл опубликован: 27 сен 2000
    DC motor speed is often regulated with a closed-loop speed controller using tachometer feedback. It is possible, however, to control dc motor speed without tachometer feedback.
  • MTTF, Failrate, Reliability, and Life Testing
    PDF, 51 Кб, Файл опубликован: 4 окт 2000
    At Burr-Brown, we characterize and qualify the reliability of our devices through high temperature life testing. The results of this testing are quantified with such values as MTTF and failure rate. This information can be very valuable when used for comparative purposes or applied to reliablility calculations. However, this information loses its worth if it is not precisely understood and appropr
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
OPA544T1, OPA544T 1
На английском языке: Datasheet Texas Instruments OPA544T-1
