Datasheet Texas Instruments ADS7885SDBVR — Даташит
СерияADS7885
МодельADS7885SDBVR
2,7–5,5 В, 8 бит, 3 MSPS, последовательный АЦП 6-SOT-23 от -40 до 125
10-/8-Bit, 3-MSPS, microPOWER, Miniature SAR Analog-to-Digital Converters datasheet
PDF, 1.2 Мб, Файл опубликован: 24 авг 2007
АЦП азиатских производителей
Pin6
Package TypeDBV
Industry STD TermSOT-23
Package QTY3000
Маркировка7885
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
# Input Channels1
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)2.7 В
АрхитектураSAR
Digital Supply(Max)5.5 В
Digital Supply(Min)2.7 В
INL(Max)0.4 +/-LSB
Input Range(Max)5.5 В
Тип входаSingle-Ended
Integrated FeaturesN/A
InterfaceSPI
Multi-Channel ConfigurationN/A
Package GroupSOT-23
Package Size: mm2:W x L6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Power Consumption(Typ)15 mW
Reference ModeSupply
Разрешение8 Bits
SINAD49.8 дБ
Sample Rate (max)3MSPS SPS
Sample Rate(Max)3 MSPS
THD(Typ)-68 дБ
  • Evaluation Modules & Boards: ADS7885EVM
    ADS7885 Evaluation Module
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS7885 (2)
На английском языке: Datasheet Texas Instruments ADS7885SDBVR
