Datasheet Texas Instruments THS6093ID — Даташит
СерияTHS6093
МодельTHS6093ID
Драйвер линии ADSL CPE, 275 мА, +12 В с отключением 14-SOIC от -40 до 85
200 mA +/- 12 V ADSL CPE Line Drivers datasheet
PDF, 1.2 Мб, Версия: C, Файл опубликован: 11 окт 2002
Pin14
Package TypeD
Package QTY50
МаркировкаTHS6093I
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураCurrent FB
BW @ Acl100 МГц
CMRR(Min)55 дБ
CMRR(Typ)63 дБ
GBW(Typ)100 МГц
Input Bias Current(Max)10000000 pA
Iq per channel(Max)9.5 мА
Iq per channel(Typ)7.3 мА
Количество каналов2
Offset Drift(Typ)20 uV/C
Output Current(Typ)275 мА
Rail-to-RailNo
Slew Rate(Typ)600 V/us
Total Supply Voltage(Max)14 +5V=5, +/-5V=10
Total Supply Voltage(Min)5 +5V=5, +/-5V=10
Vn at Flatband(Typ)2.1 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)16 мВ
  • Evaluation Modules & Boards: THS6093EVM
    THS6093 Evaluation Module
  • Active Output Impedance for ADSL Line Drivers
    PDF, 636 Кб, Файл опубликован: 26 ноя 2002
    Signal termination is very common in bidirectional communication systems. Termination allows for receiving signals while transmitting different signals at the same time. With the increasing popularity of asymmetrical digital subscriber lines (ADSL), the requirement for a low power line driver amplifier combined with line termination becomes a very difficult goal. This application note examines the
На английском языке: Datasheet Texas Instruments THS6093ID
