Datasheet Texas Instruments LM3424MHX/NOPB — Даташит
СерияLM3424
МодельLM3424MHX/NOPB
N-канальный контроллер постоянного тока с термической обратной связью для управления светодиодами 20-HTSSOP от -40 до 125
LM3424/-Q1 Constant Current N-Channel Controller with Thermal Foldback for Driving LEDs datasheet
PDF, 2.1 Мб, Версия: C, Файл опубликован: 12 авг 2015
Pin2020
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаMHLM3424
Width (мм)4.44.4
Length (мм)6.56.5
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Dimming MethodAnalog,PWM
Входное напряжениеDC/DC Type
Iout(Max)5 A
Iq(Typ)2 мА
Package GroupHTSSOP
Package Size: mm2:W x L20HTSSOP: 42 mm2: 6.4 x 6.5(HTSSOP) PKG
Power Factor CorrectionN/A Min
Regulated Outputs1
Special FeaturesAdjustable Switch Frequency,Enable/Shutdown,Power Good,Soft Start,Synchronization Pin,Thermal Shutdown
Switching Frequency(Max)2000 kHz
Switching Frequency(Min)25 kHz
TopologyBoost,Boost Controller,Buck-Boost,Sepic
ТипController,Inductive
Vin(Max)75 В
Vin(Min)4.5 В
Vout(Max)72 В
Vout(Min)3 В
Vref1.24 В
  • Evaluation Modules & Boards: LM3424BSTEVAL
    LM3424 Boost Evaluation Board
  • Evaluation Modules & Boards: LM3424BKBSTEVAL
    LM3424 Buck-Boost Evaluation Board
  • AN-1982 Small, Wide Input Voltage Range LM2842 Keeps LEDs Cool (Rev. A)
    PDF, 60 Кб, Версия: A, Файл опубликован: 23 апр 2013
    The world seems to be poised to make the leap to LED lighting. Incandescent has been deemed tooinefficient, which it is, and fluorescent lighting often does not achieve the lifetime it claims. Fluorescentalso has another set of baggage, dangerous chemicals. So the logical choice that most people believe cantake the crown is high brightness (HB) LEDs. HBLEDs are becoming more attractive as th
  • AN-1656 Design Challenges of Switching LED Drivers (Rev. A)
    PDF, 171 Кб, Версия: A, Файл опубликован: 3 май 2013
    Using a switching regulator as an LED driver requires the designer to convert a voltage regulator into acurrent regulator. Beyond the challenge of changing the feedback system to control current, the LEDsthemselves present a load characteristic that is much different than the digital devices and other loads thatrequire constant voltage. The LED WEBENCHВ® online design environment predicts and
Серия: LM3424 (2)
  • Semiconductors > Power Management > LED Driver > Illumination & General Lighting LED Driver
На английском языке: Datasheet Texas Instruments LM3424MHX/NOPB
