Datasheet Texas Instruments LM3404MA/NOPB — Даташит
СерияLM3404
МодельLM3404MA/NOPB
Понижающий стабилизатор постоянного тока 1,0 А для драйверов светодиодов высокой мощности 8-SOIC от -40 до 125
LM3404xx 1-A Constant Current Buck Regulator for Driving High Power LEDs datasheet
PDF, 1.5 Мб, Версия: G, Файл опубликован: 29 сен 2015
42 предложений от 20 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Устройства управления светодиодами
LM3404MA/NOPB
128 ₽
LM3404MA/NOPB
от 281 ₽
727GS
LM3404MA/NOPB
Hi-Tech Circuit Group
LM3404MA/NOPB
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9595
CarrierTUBETUBE
МаркировкаL3404MA
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Dimming MethodPWM
Входное напряжениеDC/DC Type
Iout(Max)1 A
Iq(Typ)0.625 мА
Power Factor CorrectionN/A Min
Regulated Outputs1
Special FeaturesAdjustable Switch Frequency,Enable/Shutdown,Integrated Switch,Thermal Shutdown
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)20 kHz
TopologyBuck
ТипInductive
Vin(Max)42 В
Vin(Min)6 В
Vout(Max)40 В
Vout(Min)0.2 В
Vref0.2 В
  • Evaluation Modules & Boards: LM3404FSTDIMEV
    LM3404FSTDIMEV - Fast Dimming and True Constant LED Current Evaluation Board
  • Evaluation Modules & Boards: LM3404MREVAL
    LM3402 LM3404 High Power PSOP-8 Evaluation board
  • Evaluation Modules & Boards: LM3404EVAL
    LM3404MA (SOIC) - 1A Constant Current Buck Regulator for HB LEDs (LM3404EVAL Board)
  • Thermal Performance of the LM3404/04HV in SO-8 and PSOP-8 Packages (Rev. A)
    PDF, 146 Кб, Версия: A, Файл опубликован: 1 май 2013
    The LM3404/04HV is a buck-regulator designed for driving high powered LEDs at forward currents of upto 1.0A. LED drivers often experience thermal conditions that are extreme even by the standards ofswitching converters. For example, LED drivers are often placed on the same metal-core PCB (MCPCB)as the LEDs themselves. At 1.0A, a single-die white LED can dissipate more than 3W. The temperatur
  • AN-1853 COT Drivers Control LED Ripple Current (Rev. A)
    PDF, 76 Кб, Версия: A, Файл опубликован: 1 май 2013
    The constant on-time (COT) control method used by the LM3402 and LM3404 constant-current buckregulators provides a balance between control over switching frequency and fast transient response.Normally this "quasi-hysteretic" control senses the input voltage and adjusts the on-time tON of the powerMOSFET as needed to keep fSW constant. Investigating a little more deeply reveals that tON is in
  • AN-1982 Small, Wide Input Voltage Range LM2842 Keeps LEDs Cool (Rev. A)
    PDF, 60 Кб, Версия: A, Файл опубликован: 23 апр 2013
    The world seems to be poised to make the leap to LED lighting. Incandescent has been deemed tooinefficient, which it is, and fluorescent lighting often does not achieve the lifetime it claims. Fluorescentalso has another set of baggage, dangerous chemicals. So the logical choice that most people believe cantake the crown is high brightness (HB) LEDs. HBLEDs are becoming more attractive as th
  • Driving LEDs: To Cap or Not to Cap
    PDF, 542 Кб, Файл опубликован: 21 мар 2007
  • AN-1656 Design Challenges of Switching LED Drivers (Rev. A)
    PDF, 171 Кб, Версия: A, Файл опубликован: 3 май 2013
    Using a switching regulator as an LED driver requires the designer to convert a voltage regulator into acurrent regulator. Beyond the challenge of changing the feedback system to control current, the LEDsthemselves present a load characteristic that is much different than the digital devices and other loads thatrequire constant voltage. The LED WEBENCHВ® online design environment predicts and
Серия: LM3404 (4)
  • Semiconductors > Power Management > LED Driver > Illumination & General Lighting LED Driver
На английском языке: Datasheet Texas Instruments LM3404MA/NOPB
