Datasheet Texas Instruments LM5116MHX — Даташит
СерияLM5116
МодельLM5116MHX
Синхронный понижающий контроллер, напряжение 6–100 В, режим тока, 20-HTSSOP от -40 до 150
LM5116 Wide Range Synchronous Buck Controller datasheet
PDF, 1.5 Мб, Версия: H, Файл опубликован: 31 июл 2015
Pin2020
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаMHLM5116
Width (мм)4.44.4
Length (мм)6.56.5
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Рекомендуемая замена
ReplacementLM5116MHX/NOPB
Replacement CodeS
Duty Cycle(Max)98 %
Iout(Max)20 A
Iq(Typ)4.6 мА
Number of Phases1
Рабочий диапазон температурот -40 до 150 C
Package GroupHTSSOP
Regulated Outputs1
Special FeaturesAdjustable Current Limit,Enable,Frequency Synchronization,Light Load Efficiency,Synchronous Rectification,UVLO Adjustable
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)50 kHz
ТипController
Vin(Max)100 В
Vin(Min)6 В
Vout(Max)80 В
Vout(Min)1.215 В
RoHSSee ti.com
  • Evaluation Modules & Boards: LM5116-12EVAL
    LM5116-12 Evaluation Board
  • Evaluation Modules & Boards: LM5116BUCKEVM-BLDT
    LM5116 Wide Vin Synchronous Buck Controller PCB for Webench BuildIt
  • Evaluation Modules & Boards: LM5116EVAL
    LM5116 Wide Vin Synchronous Buck Controller Evaluation Module
  • Minimizing FET Losses For a High Input Rail Buck Converter (Rev. A)
    PDF, 168 Кб, Версия: A, Файл опубликован: 23 апр 2013
    Engineers often face the challenge of choosing the input voltage rail that works best for the DC-DCconverter at the point-of-load (POL). High voltage rails, above 12 V, usually demand intermediateregulation stages that reduce overall efficiency and add to cost. However, the new generation of regulatorand controller ICs afford POL regulation from these high input rails directly. Typically the
  • Reduce buck-converter EMI and voltage stress by minimizing inductive parasitics
    PDF, 926 Кб, Файл опубликован: 21 июл 2016
Серия: LM5116 (4)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
На английском языке: Datasheet Texas Instruments LM5116MHX
