Datasheet Texas Instruments LMH6628MAX/NOPB — Даташит
СерияLMH6628
МодельLMH6628MAX/NOPB
Двойной широкополосный малошумящий операционный усилитель с обратной связью по напряжению 8-SOIC от -40 до 85
LMH6628 Dual Wideband, Low Noise, Voltage Feedback Op Amp datasheet
PDF, 1.1 Мб, Версия: D, Файл опубликован: 15 мар 2013
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
Маркировка28MALMH66
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
2nd Harmonic65 dBc
3rd Harmonic74 dBc
@ MHz10
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураBipolar,Voltage FB
BW @ Acl300 МГц
CMRR(Min)57 дБ
CMRR(Typ)62 дБ
GBW(Typ)300 МГц
Input Bias Current(Max)20000000 pA
Iq per channel(Max)12.5 мА
Iq per channel(Typ)9 мА
Количество каналов2
Offset Drift(Typ)5 uV/C
Output Current(Typ)85 мА
Rail-to-RailNo
Slew Rate(Typ)550 V/us
Total Supply Voltage(Max)12 +5V=5, +/-5V=10
Total Supply Voltage(Min)5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)2 нВ/rtГц
Vn at Flatband(Typ)2 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)2 мВ
  • Transimpedance Amplifiers (TIA): Choosing the Best Amplifier for the job (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 16 май 2017
    This application note is intended as a guide for the designer looking to amplify the small signal from a photodiode or avalanche diode so that it would be large enough for further processing (e.g. data acquisition) or to trigger some other event in a system. The challenge in doing so, as always, is to not degrade the signal such that it becomes indistinguishable from random noi
Серия: LMH6628 (3)
На английском языке: Datasheet Texas Instruments LMH6628MAX/NOPB
