Datasheet Texas Instruments SN74ACT240DBLE — Даташит
| Серия | SN74ACT240 |
| Модель | SN74ACT240DBLE |
Восьмеричные буферы/драйверы с выходами с 3 состояниями 20-SSOP от -40 до 85
SN54ACT240, SN74ACT240 datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 7 окт 2002
OCTAL BUFFERS/DRIVERS WITH 3-STATE OUTPUTS | |||
| SN74ACT240DBLE Texas Instruments | по запросу | ||
| Статус продукта | Снят с производства (Производитель прекратил производство прибора) |
| Pin | 20 |
| Package Type | DB |
| Industry STD Term | SSOP |
| JEDEC Code | R-PDSO-G |
| Width (мм) | 5.3 |
| Length (мм) | 7.2 |
| Thickness (мм) | 1.95 |
| Pitch (мм) | .65 |
| Max Height (мм) | 2 |
| Mechanical Data | Скачать |
| Approx. Price (US$) | 0.18 | 1ku |
| Bits(#) | 8 |
| F @ Nom Voltage(Max)(Mhz) | 90 |
| ICC @ Nom Voltage(Max)(mA) | 0.04 |
| Тип входа | TTL |
| Operating Temperature Range(C) | -40 to 85 |
| Output Drive (IOL/IOH)(Max)(mA) | -24/24 |
| Тип выхода | CMOS |
| Package Group | SSOP |
| Package Size: mm2:W x L (PKG) | See datasheet (PDIP) |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | ACT |
| VCC(Max)(V) | 5.5 |
| VCC(Min)(V) | 4.5 |
| Voltage(Nom)(V) | 5 |
| tpd @ Nom Voltage(Max)(ns) | 9.5 |
| RoHS | Не совместим |
| Бессвинцовая технология (Pb Free) | Нет |
- Understanding Thermal Dissipation and Design of a HeatsinkPDF, 59 Кб, Файл опубликован: 4 май 2011
Power dissipation performance must be well understood prior to integrating devices on a printed-circuit board (PCB) to ensure that any given device is operated within its defined temperature limits. When a device is running, it consumes electrical energy that is transformed into heat. Most of the heat is typically generated by switching devices like MOSFETs, ICs, etc. This application report discu
Серия: SN74ACT240 (14)
- Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
