Линейка продуктов KEEN SIDE
Datasheet Texas Instruments 74CB3T3306DCURE4 — Даташит
СерияSN74CB3T3306
Модель74CB3T3306DCURE4
Транслятор напряжения с двойным переключателем шины 8-VSSOP от -40 до 85
SN74CB3T3306 Dual FET Bus Switch 2.5-V/3.3-V Low-Voltage Bus Switch With 5-V Tolerant Level Shifter datasheet
PDF, 895 Кб, Версия: C, Файл опубликован: 31 дек 2015
Package TypeDCU
Industry STD TermVSSOP
Width (мм)2
Length (мм)2.3
Thickness (мм).85
Pitch (мм).5
Max Height (мм).9
Additional FeaturesLow Power
5-3.3V Translation
IOFF
Approx. Price (US$)0.59 | 1ku
Bandwidth(MHz)100
ConfigurationSPST
ESD Charged Device Model(kV)1
ESD HBM(kV)2
ICC(Max)(uA)20
Input/Ouput Voltage(Max)(V)5.5
Input/Output Continuous Current(Max)(mA)128
Number of Channels(#)2
Operating Temperature Range(C)-40 to 85
Package GroupVSSOP
Package Size: mm2:W x L (PKG)8VSSOP: 6 mm2: 3.1 x 2(VSSOP)
Ron(Max)(Ohms)9.5
Ron(Typ)(Ohms)5
VCC(Max)(V)3.6
VCC(Min)(V)2.3
RoHSНе совместим
  • CBT-C, CB3T, and CB3Q Signal-Switch Families
    PDF, 584 Кб, Файл опубликован: 4 фев 2003
    Signal switch devices are widely used in applications requiring bus isolation, multiplexing, demultiplexing, and voltage translation. Compared to other logic and linear product alternatives, signal switches are the fastest and least power consuming. Texas Instruments (TI) CBT-C, CB3Q, and CB3T signal-switch families have low on-state resistance, negligible power consumption, and better undershoot
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
На английском языке: Datasheet Texas Instruments 74CB3T3306DCURE4
