Datasheet Texas Instruments TPS259270DRCR — Даташит
СерияTPS25927
МодельTPS259270DRCR
18V, 5A, 28mО© eFuse with BFET Driver for Reverse Current Protection 10-VSON -40 to 85
TPS25927x 4.5-V to 18-V eFuse with Blocking FET Control datasheet
PDF, 1.6 Мб, Версия: D, Файл опубликован: 6 янв 2017
Pin10
Package TypeDRC
Industry STD TermVSON
JEDEC CodeS-PDSO-N
Package QTY3000
Маркировка259270
Width (мм)3
Length (мм)3
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Current Limit Accuracy+/-8%
Current Limit Function EnabledAlways
Current Limit TypeAdjustable
Current Limit(Max)5 A
Current Limit(Min)1 A
FET ProtectionThermal
Fault ResponseLatch Off
Imax5 A
Количество каналов1
ON_OFF Control InputENUV s
Overcurrent ResponseCurrent Limiting
Package GroupVSON
Package Size: mm2:W x L10VSON: 9 mm2: 3 x 3(VSON) PKG
Rise Time(Typ)1000 us
Ron(Typ)28 mOhm
Special FeaturesOvervoltage Protection,Reverse Current Protection,Thermal Shutdown,Under Voltage Lock Out
UL RecognitionYes
Vabsmax_cont20 В
Vin(Max)18 В
Vin(Min)4.5 В
  • Evaluation Modules & Boards: TPS259230-41EVM
    TPS25923/4/7, Simple 5V/12V eFuse Protection Switches Evaluation Module
Серия: TPS25927 (4)
  • Semiconductors > Power Management > Protection, Monitoring and Hot Swap > eFuses (Integrated FET)
На английском языке: Datasheet Texas Instruments TPS259270DRCR
