Datasheet Texas Instruments REF1004C-2.5/2K5E4 — Даташит
СерияREF1004-2.5
МодельREF1004C-2.5/2K5E4
Опорное напряжение микромощности 8-SOIC от 0 до 70
Micropower Voltage Reference datasheet
PDF, 248 Кб, Файл опубликован: 27 сен 2000
Опорный чип напряжения, V-Ref Precision 2.5V 20mA 8Pin SOIC T/R
REF1004C-2.5/2K5E4
111 ₽
REF1004C-2.5/2K5E4
146 ₽
REF1004C-2.5/2K5E4
REF1004C-2.5/2K5E4
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
Маркировка0425REF
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Initial Accuracy(Max)0.8 %
Iout/Iz(Max)20 мА
Min Iz for Regulation12 uA
Pin/Package8SOIC
Reference VoltageFixed
Temp Coeff(Typ)20 ppm/ degree C
VO2.5 В
VO Adj(Max)2.5 В
VO Adj(Min)2.5 В
WBN 10-10 kHz(Typ)120 uVrms
  • How to get 23 bits of effective resolution from your 24-bit converter
    PDF, 96 Кб, Файл опубликован: 27 сен 2000
    The ADS1210 and ADS1211 are precision, wide dynamic range, delta-sigma A/D converters that have 24 bits of no missing code and up to 23 bits rms of effective resolution. Because of the nature of the delta-sigma design architecture the circuit designer has control over more of the variables and interface options in the A/D's conversion process than is realizable with other converter architectures.
  • Comparing the ADS1201 to the CS5321 [745k]
    PDF, 212 Кб, Файл опубликован: 27 сен 2000
    The intent of this application bulletin is to provide a simple means of comparing the operation of the ADS1201 delta-sigma modulator to Crystal's CS5321 delta-sigma modulator. It is not the intent of this document to descibe the theory or the operation behind delta-sigma modulators, it is merely to provide the methodology, configuration, and results of tests that were performed using these modulat
  • Remove the DC Portion of Signals with the ADS7817
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    Unwanted portions of a signal, such as a DC pedestal, can be difficult to reject in a single supply circuit. A DC pedestal voltage most typically appears at the output of an operational amplifier with a small signal riding on top of it. This pedestal voltage is required in the analog domain to insure that the small signal that contains the pertinent information never falls below the ground potenti
REF1004C2.5/2K5E4, REF1004C 2.5/2K5E4
На английском языке: Datasheet Texas Instruments REF1004C-2.5/2K5E4
