Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74AVCA406LGQSR — Даташит
СерияSN74AVCA406L
МодельSN74AVCA406LGQSR
Трансивер преобразования напряжения MMC, SD-карты и карты памяти Memory Stick 24-BGA MICROSTAR JUNIOR от -40 до 85
SN74AVCA406L Voltage-Translation Transceiver datasheet
PDF, 557 Кб, Версия: B, Файл опубликован: 30 май 2006
Pin24
Package TypeGQS
Industry STD TermBGA MICROSTAR JUNIOR
JEDEC CodeS-PBGA-N
Package QTY2500
МаркировкаWM406L
Width (мм)3
Length (мм)3
Thickness (мм).79
Pitch (мм).5
Max Height (мм)1
Bits7
ICCA Static Current0.01 мА
ICCB Static Current0.01 мА
Package GroupBGA MICROSTAR JUNIOR
Package Size: mm2:W x L20BGA MICROSTAR JUNIOR: 8 mm2: 3 x 2.5(BGA MICROSTAR JUNIOR) PKG
Special FeaturesSD/SDIO/MMC Card
Static Current0.015 мА
VCCA(Max)3.6 В
VCCA(Min)1.2 В
VCCB(Max)3.6 В
VCCB(Min)1.2 В
RoHSSee ti.com
  • Dynamic Output Control (DOC) Circuitry Technology And Applications (Rev. B)
    PDF, 126 Кб, Версия: B, Файл опубликован: 7 июл 1999
    Texas Instruments (TI[TM]) next-generation logic is called the Advanced Very-low-voltage CMOS (AVC) family. The AVCfamily features TI?s Dynamic Output Control (DOC[TM]) circuit (patent pending). DOC circuitry automatically lowers the outputimpedance of the circuit at the beginning of a signal transition, providing enough current to achieve high signaling speeds, thensubsequently raises the i
  • AVC Logic Family Technology and Applications (Rev. A)
    PDF, 148 Кб, Версия: A, Файл опубликован: 26 авг 1998
    Texas Instruments (TI?) announces the industry?s first logic family to achieve maximum propagation delays of less than 2 ns at 2.5 V. TI?s next-generation logic is the Advanced Very-low-voltage CMOS (AVC) family. Although optimized for 2.5-V systems, AVC logic supports mixed-voltage systems because it is compatible with 3.3-V and 1.8-V devices. The AVC family features TI?s Dynamic Output Control (
  • Voltage Translation Between 3.3-V, 2.5-V, 1.8-V, and 1.5-V Logic Standards (Rev. B)
    PDF, 390 Кб, Версия: B, Файл опубликован: 30 апр 2015
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN74AVCA406L (3)
  • Semiconductors > Logic > Voltage Level Translation > Application Specific Voltage Translation
На английском языке: Datasheet Texas Instruments SN74AVCA406LGQSR
