Datasheet Texas Instruments LMT89DCKT — Даташит
СерияLMT89
МодельLMT89DCKT
Датчик температуры с аналоговым выходом 2,4 В, 10 мкА 5-SC70 от -55 до 130
LMT89 2.4-V, 10-µA, SC70 Temperature Sensor datasheet
PDF, 1.0 Мб, Версия: A, Файл опубликован: 31 янв 2015
Pin5
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY250
CarrierSMALL T&R
МаркировкаT3B
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
InterfaceAnalog Output
Local Sensor Accuracy(Max)2.5 +/- C
Рабочий диапазон температурот -55 до 130 C
Output Impedance160 Ohm
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
Sensor Gain-11.77 mV/Deg C
Special FeaturesIndustry standard pinout
Supply Current(Max)7 uA
Supply Voltage(Max)5.5 В
Supply Voltage(Min)2.4 В
  • Evaluation Modules & Boards: LMT88-9EVM
    LMT88 and LMT89 Temperature Sensor EVM
  • SC Temp Sensors Challenge Precision RTDs and Thermistors in Build Automation
    PDF, 247 Кб, Файл опубликован: 21 апр 2015
    Standalone semiconductor sensors have rarely been considered for implementation into sensor probes or assemblies due to their larger geometries. However, advances in process technology and design have led to new, tiny sensor structures with almost linear transfer functions.In order to provide system designers with this new low-cost alternative to precision temperature measurement, this appl
Серия: LMT89 (2)
  • Semiconductors > Sensing Products > Temperature Sensors > Local Analog Temperature Sensors
На английском языке: Datasheet Texas Instruments LMT89DCKT
