Datasheet Texas Instruments UCC28521DWR — Даташит
СерияUCC28521
МодельUCC28521DWR
Усовершенствованный комбинированный контроллер PWM/PFC с модуляцией TEM/TEM 20-SOIC от -40 до 85
Advanced PFC/PWM Combination Controller w/Trailing-Edge/Trailing-Edge Modulation datasheet
PDF, 781 Кб, Версия: D, Файл опубликован: 15 ноя 2005
Pin20
Package TypeDW
Width (мм)7.5
Length (мм)12.8
Thickness (мм)2.35
Max Height (мм)2.65
Рекомендуемая замена
ReplacementUCC28510DW
Replacement CodeF
Approx. Price (US$)2.15 | 1ku
Control MethodCCM
Device TypePFC+PWM
Operating Supply Current(mA)4
Operating Supply(Max)(V)18
Operating Temperature Range(C)-40 to 85
Package Size: mm2:W x L (PKG)20SOIC: 132 mm2: 10.3 x 12.8(SOIC)
Peak Output Sink Current Gate Drive(A)3.5
Peak Output Source Current Gate Drive(A)-2.5
Practical Operating Frequency(Max)(MHz)0.5
Special Features750W Applications
Average Current Mode
Enable
Startup Current(mA)0.1
UVLO Thresholds On/Off(V)10.2/9.7
RoHSНе совместим
  • Evaluation Modules & Boards: UCC28528EVM
    UCC28528 Evaluation Module
  • Evaluation Modules & Boards: UCC28521EVM
    UCC28521 Evaluation Module
  • UCC28517 100-W PFC power converter with 12-V, 8-W bias supply, Part 2
    PDF, 224 Кб, Файл опубликован: 28 фев 2005
    To conclude the review of the UCC28517 PFC supply, this article covers the design of the second 12-V, 8-W power stage to be used as an auxiliary bias supply.
  • UCC28517 100-W PFC power converter with 12-V, 8-W bias supply, Part 1
    PDF, 202 Кб, Файл опубликован: 28 фев 2005
    Power factor corrected (PFC) preregulators are generally used in ac/dc converters operating above 75 W or to meet line harmonic requirements. This article reviews the design of a 100-W ac/dc power stage with PFC.
  • A New Synchronization Circuit for Power Converters (Rev. A)
    PDF, 209 Кб, Версия: A, Файл опубликован: 21 апр 2010
    The synchronization of multiple PWM and PFC controllers is desirable for many reasons. The most common reason is that it keeps all the noise at one particular frequency and makes it easier to filter. The circuit described changes the slope of the ramp to lock the converter’s switching frequency to an applied signal by a phase locked loop turning it into a voltage controlled oscillator. Furthermore
Серия: UCC28521 (3)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Power Factor Correction
На английском языке: Datasheet Texas Instruments UCC28521DWR
