Datasheet Texas Instruments LMH6521SQX/NOPB — Даташит
СерияLMH6521
МодельLMH6521SQX/NOPB
Высокопроизводительный двойной DVGA 32-WQFN от -40 до 85
LMH6521 High Performance Dual DVGA datasheet
PDF, 2.0 Мб, Версия: E, Файл опубликован: 23 авг 2016
Pin32
Package TypeRTV
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY4500
МаркировкаL6521SQ
Width (мм)5
Length (мм)5
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Acl, min spec gain0.53 V/V
BW @ Acl1400 МГц
Max Gain26 дБ
Количество каналов2
PGA/VGAVGA
Package GroupWQFN
Package Size: mm2:W x L32WQFN: 25 mm2: 5 x 5(WQFN) PKG
Vs(Max)5.25 В
Vs(Min)4.75 В
  • Evaluation Modules & Boards: TSW16DX370EVM
    TSW16DX370EVM Evaluation Module
  • Evaluation Modules & Boards: TSW1265EVM
    Wideband Dual Receiver Reference Design and Evaluation Platform
  • Evaluation Modules & Boards: LMH6521EVAL
    Evaluation Board for the LMH6521
  • Evaluation Modules & Boards: TSW1266EVM
    Wideband RF-to-Digital Complex Feedback Receiver: Dual 12-Bit 800MSPS ADC, DVGA and Clock Solution
  • AN-2235 Ckt Brd Design for LMH6517/21/22 & Other H-Sp IF/RF F Amp (Rev. A)
    PDF, 3.2 Мб, Версия: A, Файл опубликован: 1 май 2013
    High-bandwidth, high-performance amplifiers require care in board layout techniques in order to ensureoptimum performance. This paper will address the key components of PCB design for high-performanceamplifiers, including the new LMH6521 and LMH6522 DVGAs.
  • A Walk Along the Signal Path (High-Speed Signal Path)
    PDF, 461 Кб, Файл опубликован: 30 мар 2005
  • Using High Speed Diff Amp to Drive ADCs (Rev. A)
    PDF, 175 Кб, Версия: A, Файл опубликован: 26 апр 2013
    The right high speed differential amplifier will add flexibility to signal chains that include a high speedanalog-to-digital converter (ADC). A differential amplifier can provide signal conditioning such as singleended to differential conversion, impedance transformation, and gain or attenuation.
  • AN-1719 Noise Figure Analysis Fully Differential Amplifier (Rev. A)
    PDF, 97 Кб, Версия: A, Файл опубликован: 1 май 2013
    This application note provides noise figure analysis for fully differential amplifiers, including output noisecalculation and noise figure calculation.
  • Between the Amplifier and ADC: Managing Filter Loss in Communications Systems (Rev. B)
    PDF, 114 Кб, Версия: B, Файл опубликован: 26 апр 2013
    This application report discusses managing filter loss in communications systems.
  • Drivng HSpeed ADCs w/LMH6521 DVGA for High IF AC-Coupled Apps (Rev. A)
    PDF, 1.2 Мб, Версия: A, Файл опубликован: 26 апр 2013
    This application report discusses driving high speed ADCs with the Texas Instruments LMH6521 DVGAfor high IF AC-coupled applications.
Серия: LMH6521 (3)
  • Semiconductors > Amplifiers > Programmable & Variable Gain Amplifiers (PGA/VGA)
На английском языке: Datasheet Texas Instruments LMH6521SQX/NOPB
