Datasheet Texas Instruments SN74ACT240PWRG4 — Даташит
СерияSN74ACT240
МодельSN74ACT240PWRG4
Восьмеричные буферы/драйверы с выходами с 3 состояниями 20-TSSOP от -40 до 85
SN54ACT240, SN74ACT240 datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 7 окт 2002
Pin20
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаAD240
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
Bits8
F @ Nom Voltage(Max)90 Mhz
ICC @ Nom Voltage(Max)0.04 мА
Output Drive (IOL/IOH)(Max)-24/24 мА
Package GroupTSSOP
Schmitt TriggerNo
Technology FamilyACT
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)9.5 нс
  • Understanding Thermal Dissipation and Design of a Heatsink
    PDF, 59 Кб, Файл опубликован: 4 май 2011
    Power dissipation performance must be well understood prior to integrating devices on a printed-circuit board (PCB) to ensure that any given device is operated within its defined temperature limits. When a device is running, it consumes electrical energy that is transformed into heat. Most of the heat is typically generated by switching devices like MOSFETs, ICs, etc. This application report discu
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74ACT240PWRG4
