Datasheet Texas Instruments ADS8411IBPFBT — Даташит
Серия | ADS8411 |
Модель | ADS8411IBPFBT |
16-разрядный АЦП, 2 MSPS, параллельный выход P8/P16, внутренняя тактовая частота и внутренний опорный сигнал 48-TQFP от -40 до 85
16-Bit, 2 MSPS, Unipolar Input, Micropower Sampling Analog to Digital Converter datasheet
PDF, 1.5 Мб, Версия: B, Файл опубликован: 17 дек 2004
Pin | 48 | 48 |
Package Type | PFB | PFB |
Industry STD Term | TQFP | TQFP |
JEDEC Code | S-PQFP-G | S-PQFP-G |
Package QTY | 250 | 250 |
Carrier | SMALL T&R | SMALL T&R |
Маркировка | ADS8411I | B |
Width (мм) | 7 | 7 |
Length (мм) | 7 | 7 |
Thickness (мм) | 1 | 1 |
Pitch (мм) | .5 | .5 |
Max Height (мм) | 1.2 | 1.2 |
# Input Channels | 1 |
Analog Voltage AVDD(Max) | 5.25 В |
Analog Voltage AVDD(Min) | 4.75 В |
Архитектура | SAR |
Digital Supply(Max) | 5.25 В |
Digital Supply(Min) | 2.7 В |
INL(Max) | 2.5 +/-LSB |
Input Range(Max) | 4.1 В |
Тип входа | Pseudo-Differential,Single-Ended |
Integrated Features | Oscillator |
Interface | Parallel |
Multi-Channel Configuration | N/A |
Package Group | TQFP |
Package Size: mm2:W x L | 48TQFP: 81 mm2: 9 x 9(TQFP) PKG |
Power Consumption(Typ) | 155 mW |
Rating | Catalog |
Reference Mode | Ext,Int |
Разрешение | 16 Bits |
SINAD | 85 дБ |
SNR | 86 дБ |
Sample Rate (max) | 2MSPS SPS |
Sample Rate(Max) | 2 MSPS |
THD(Typ) | -90 дБ |
- Using ADS8411/2 (16-Bit 2MSPS SAR) as a Serial ADCPDF, 438 Кб, Файл опубликован: 24 май 2004
This application report discusses how to use a parallel ADC as a serial ADC by using a low-cost CPLD. This concept is tested with a Texas Instruments ADS8411/12 (16-bit, 2 MSPS SAR ADC) and an Altera(TM) MAX 3000A CPLD. A full solution with a schematic, layout, and software for programming the CPLD is presented at the end of the report. - Interfacing the ADS8401/ADS8411 to TMS320C6713 DSPPDF, 260 Кб, Файл опубликован: 23 сен 2004
This application report presents a solution for interfacing the ADS8401 and ADS8411 16-bit, parallel interface converters to the TMS320C6713 DSP. The hardware solution consists of existing hardware, specifically the ADS8411EVM, 'C6713 DSK, and 5-6K interface board. The software demonstrates how to use an EDMA ping-pong buffer and Timer1 peripherals to collect data at 2 MSPS. Discussed also are som - Accurately measuring ADC driving-circuit settling time (Rev. A)PDF, 107 Кб, Версия: A, Файл опубликован: 18 май 2015
- Using ADS8411 in a Multiplexed Analog Input Application (Rev. A)PDF, 2.1 Мб, Версия: A, Файл опубликован: 15 фев 2006
This application report is intended as a guide for using an analog multiplexer to multiplex several input signals to a single high-resolution, high-speed SAR analog-to-digital converter (ADC). The ADC and the multiplexer used were the ADS8411 and the TS5A3159/3359, respectively. This document discusses the important parameters of a multiplexer and defines a few important measurements for evaluatin - Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
Серия: ADS8411 (3)
- ADS8411IBPFBR ADS8411IBPFBT ADS8411IPFBT
