Datasheet Texas Instruments SN74LVC07AQPWRQ1 — Даташит
СерияSN74LVC07A-Q1
МодельSN74LVC07AQPWRQ1
Автомобильный каталог Шестигранный буфер/драйвер с выходами с открытым стоком 14-TSSOP от -40 до 125
Hex Buffer and Driver With Open-Drain Outputs datasheet
PDF, 739 Кб, Версия: D, Файл опубликован: 17 июл 2012
Pin14
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаLVC07AQ
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Bits6
F @ Nom Voltage(Max)110 Mhz
ICC @ Nom Voltage(Max)0.01 мА
Output Drive (IOL/IOH)(Max)-24/24 мА
Package GroupTSSOP
Package Size: mm2:W x L14TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
RatingAutomotive
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3,5 В
tpd @ Nom Voltage(Max)3.5,2.8,3,2.9 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC07A-Q1 (2)
На английском языке: Datasheet Texas Instruments SN74LVC07AQPWRQ1
Публикации по теме
