Datasheet Texas Instruments SN54AS1034AJ — Даташит
СерияSN54AS1034A
МодельSN54AS1034AJ
Шестнадцатеричные драйверы 14-CDIP от -55 до 125
Hex Drivers datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 1 янв 1995
Pin14
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Package QTY1
МаркировкаSN54AS1034AJ
Width (мм)6.67
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Bits6
Тип входаTTL
Тип выходаTTL
Package GroupCDIP
RatingMilitary
Schmitt TriggerNo
Technology FamilyAS
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
RoHSSee ti.com
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
Серия: SN54AS1034A (3)
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Buffer Drivers
На английском языке: Datasheet Texas Instruments SN54AS1034AJ
