Datasheet Texas Instruments TPA3002D2PHPR — Даташит
СерияTPA3002D2
МодельTPA3002D2PHPR
Стереоусилитель мощности звука класса D, 9 Вт с регулятором громкости (TPA3002) 48-HTQFP от -40 до 85
9-W Stereo Class-D Audio Power Amplifier w/DC Volume Control datasheet
PDF, 847 Кб, Версия: C, Файл опубликован: 28 мар 2004
Pin48
Package TypePHP
Industry STD TermHTQFP
JEDEC CodeS-PQFP-G
Package QTY1000
МаркировкаTPA3002D2
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Analog Supply (V)14 Min
Audio Input TypeAnalog
Closed/Open LoopOpen
Control InterfaceHardware
Package GroupHTQFP
Package Size: mm2:W x L48HTQFP: 81 mm2: 9 x 9(HTQFP) PKG
Power Stage Supply(Max)14 В
Power Stage Supply(Min)8.5 В
Power to Bridge Tied Load(Max)9 W
Speaker Channels2 Max
Supported Bridge Tied Load(Min)8 Ohms
  • Evaluation Modules & Boards: TPA3002D2EVM
    TPA3002D2 Evaluation Module (EVM)
  • RC Filter Box For Class-D Output Power and THD+N Measurement
    PDF, 636 Кб, Файл опубликован: 20 фев 2004
  • Layout Guidelines For TPA300x Series Parts
    PDF, 647 Кб, Файл опубликован: 15 июл 2003
    This article provides a well-reinforced procedure for the PCB layout task as it pertains to the TPA300x series of class D amplifiers. This information can also be used in the layout of the TPA200x series, or any other class D audio amplifier.This task needs a logical sequence. If we simply jump into the layout task, without understanding how the circuits work, we risk not having an optimal end
Серия: TPA3002D2 (3)
  • Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Analog Input Amplifiers
На английском языке: Datasheet Texas Instruments TPA3002D2PHPR
