Datasheet Texas Instruments THS5651AIPWG4 — Даташит
СерияTHS5651A
МодельTHS5651AIPWG4
10-битный цифро-аналоговый преобразователь (ЦАП) с быстродействием 125 MSPS 28-TSSOP от -40 до 85
10-Bit 125 MSPS CommsDAC datasheet
PDF, 948 Кб, Версия: A, Файл опубликован: 25 сен 2002
Pin28
Package TypePW
Industry STD TermTSSOP
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
Approx. Price (US$)4.68 | 1ku
АрхитектураCurrent Source
DAC Channels1
InterfaceParallel CMOS
Interpolation1x
Operating Temperature Range(C)-40 to 85
Package GroupTSSOP
Package Size: mm2:W x L (PKG)28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP)
Power Consumption(Typ)(mW)175
Resolution(Bits)10
SFDR(dB)77
Sample / Update Rate(MSPS)125
RoHSНе совместим
  • Evaluation Modules & Boards: THS5651EVM
    THS5651A Evaluation Module
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200EVM: Low Cost Portable Power Supply
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
  • Semiconductors > Data Converters > Digital-to-Analog Converters (DACs) > High Speed DACs (>10MSPS)
На английском языке: Datasheet Texas Instruments THS5651AIPWG4
