Datasheet Texas Instruments THS5661IPW — Даташит
СерияTHS5661
МодельTHS5661IPW
12 бит, 125 MSPS, CommsDAC, диф. Масштабируемые токовые выходы от 2 мА до 20 мА 28-TSSOP от -40 до 85
Datasheet
TSP
Pin28
Package TypePW
Industry STD TermTSSOP
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
RoHSНе совместим
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
Серия: THS5661 (4)
  • Semiconductors > Data Converters > Digital to Analog Converter > Precision DAC (=<10MSPS)
На английском языке: Datasheet Texas Instruments THS5661IPW
