Datasheet ТI LM3524DN/NOPB — Даташит
| Серия | LM3524D |
| Модель | LM3524DN/NOPB |
Регулирующий широтно-импульсный модулятор 16-PDIP от 0 до 80
LM2524D/LM3524D Regulating Pulse Width Modulator datasheet
PDF, 1.9 Мб, Версия: E, Файл опубликован: 2 май 2013
- AN-715 LM385 Feedback Provides Regulator Isolation (Rev. A)PDF, 93 Кб, Версия: A, Файл опубликован: 6 май 2013
This Application Note describes how to configure the LM3524 as a transformer isolated flyback power supply. - AN-272 Op Amp Booster Designs (Rev. B)PDF, 959 Кб, Версия: B, Файл опубликован: 23 апр 2013
This application report describes the output booster or post amplifier designs required to achieveneeded voltage or current gain in applications that require substantially greater output voltage swing orcurrent (or both) than IC amplifiers can deliver. - AN-694 A DMOS 3A, 55V, H-Bridge: The LMD18200 (Rev. C)PDF, 604 Кб, Версия: C, Файл опубликован: 26 апр 2013
This application note provides information on the LMD18200, which is optimized to work for applicationsthat require 0.5A to 3.0A and operate from 12V to 55V. - Applications of the LM3524 Pulse Width Modulator (Rev. B)PDF, 549 Кб, Версия: B, Файл опубликован: 23 апр 2013
The LM3524 regulating pulse-width-modulator (PWM) is commonly used as the control element inswitching regulator power supplies. This is in keeping with its intended purpose. Engineers closelyassociate this part with switching power supplies. Nevertheless, the flexible combination of elements (seebox) within the LM3524 also allows it to be used in a number of other applications outside the po - AN-288 System-Oriented DC-DC Conversion Techniques (Rev. B)PDF, 833 Кб, Версия: B, Файл опубликован: 6 май 2013
This application note discusses the operation of system-oriented DC-DC conversion techniques.
Серия: LM3524D (3)
- LM3524DM/NOPB LM3524DMX/NOPB LM3524DN/NOPB
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Controller (External Switch)
