Datasheet Texas Instruments LM5046MH/NOPB — Даташит
СерияLM5046
МодельLM5046MH/NOPB
Полномостовой ШИМ-контроллер с фазовым сдвигом и встроенными драйверами MOSFET 28-HTSSOP от -40 до 125
LM5046 Phase-Shifted Full-Bridge PWM Controller With Integrated MOSFET Drivers datasheet
PDF, 1.6 Мб, Версия: H, Файл опубликован: 3 май 2013
Pin2828
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY4848
CarrierTUBETUBE
МаркировкаLM5046MH
Width (мм)4.44.4
Length (мм)9.79.7
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Control MethodCurrent,Voltage
Duty Cycle(Max)50 %
Frequency(Max)2000 kHz
Frequency(Min)100 kHz
Gate Drive(Typ)1.5,2 A
Package GroupHTSSOP
Special FeaturesSynchronization Pin
TopologyPhase-Shifted Full-Bridge
UVLO Thresholds On/OffProgrammable/1.25V В
Vin(Max)100 В
Vin(Min)14 В
  • Evaluation Modules & Boards: LM5046EVAL
    Evaluation Board for the LM5046
  • AN-2116 SolarMagic ICs in Micro-inverter Applications (Rev. B)
    PDF, 101 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application report explores some of the prevalent topologies used in microinverters today, and theuse of SolarMagicв„ў ICs in these demanding applications. In particular, the use of the SM72295Photovoltaic Full-Bridge Driver is highlighted.
  • AN-2126 LM5046 Based Eighth Brick Reference Design (Rev. B)
    PDF, 7.0 Мб, Версия: B, Файл опубликован: 6 май 2013
    The LM5046 reference board is designed in the telecom industry standard one-eighth brick footprint basedon the phase-shifted full-bridge topology. This board is for reference only and is intended to demonstratethe capability of the LM5046. Hardware is not provided for evaluation. Please refer to AN-2115 LM5046Evaluation Board (SNVA470) for more information.
  • Using a Phase-Shifted Full-Bridge Topology in Small Form Factor Power Converters
    PDF, 2.1 Мб, Файл опубликован: 31 авг 2011
Серия: LM5046 (4)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments LM5046MH/NOPB
