Datasheet Texas Instruments ADS7866IDBVTG4 — Даташит
СерияADS7866
МодельADS7866IDBVTG4
1,2 В, 12 бит, 200 KSPS, последовательный АЦП 6-SOT-23 от -40 до 85
1.2-V 12/10/8-Bit 200-KSPS/100-KSPS MICRO-POWER MINIATURE ADC s/Serial Interface datasheet
PDF, 1.1 Мб, Файл опубликован: 1 июл 2005
АЦП азиатских производителей
Pin6
Package TypeDBV
Industry STD TermSOT-23
Package QTY250
CarrierSMALL T&R
МаркировкаA66Y
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
# Input Channels1
Analog Voltage AVDD(Max)3.6 В
Analog Voltage AVDD(Min)1.2 В
АрхитектураSAR
Digital Supply(Max)3.6 В
Digital Supply(Min)1.2 В
INL(Max)1.5 +/-LSB
Input Range(Max)3.6 В
Тип входаSingle-Ended
Integrated FeaturesN/A
InterfaceSPI
Multi-Channel ConfigurationN/A
Package GroupSOT-23
Package Size: mm2:W x L6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Power Consumption(Typ)0.22 mW
Reference ModeSupply
Разрешение12 Bits
SINAD70 дБ
SNR71 дБ
Sample Rate (max)200kSPS SPS
Sample Rate(Max)0.2 MSPS
THD(Typ)-83 дБ
  • Interfacing the ADS786x to TMS470 Processors
    PDF, 59 Кб, Файл опубликован: 10 июл 2006
    This application report presents methods of interfacing the ADS7866/67/68 12/10/8-bit SAR analog-to-digital converter to the serial peripheral interface (SPI) port of the TMS470 processors. The flexible clocking scheme of the TMS470 SPI port, along with its internal 16-bit shift register provides an easy hardware/software interface to this series of high-speed, micro power SAR converters.
  • Interfacing the ADS786x to the MSP430F2013
    PDF, 90 Кб, Файл опубликован: 15 июн 2006
    This application report presents methods of interfacing the ADS7866/67/68 12/10/8-bit SAR analog-to-digital converter to the MSP430F2013 universal serial interface (USI) in SPI mode. The flexible clocking scheme of the USI port, along with the internal 16-bit shift register, provides an easy hardware/software interface to this series of high-speed, micro-power SAR converters.
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS7866 (4)
На английском языке: Datasheet Texas Instruments ADS7866IDBVTG4
