Datasheet Texas Instruments TPS61005DGSRG4 — Даташит
СерияTPS61005
МодельTPS61005DGSRG4
Повышающий преобразователь низкого входного напряжения с фиксированным выходным напряжением 3,0 В 10-VSSOP от -40 до 85
TPS6100x Single- and Dual-Cell Boost Converter With Start-up Into Full Load datasheet
PDF, 594 Кб, Версия: D, Файл опубликован: 31 авг 2015
Pin10
Package TypeDGS
Industry STD TermVSSOP
JEDEC CodeS-PDSO-G
Package QTY2500
МаркировкаADF
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Pitch (мм).5
Max Height (мм)1.07
Duty Cycle(Max)100 %
Iq(Typ)0.05 мА
Package GroupVSSOP
Regulated Outputs1
Special FeaturesEnable,Light Load Efficiency,Power Good
Switch Current Limit(Min)1 A
Switch Current Limit(Typ)1 A
Switching Frequency(Max)840 kHz
Switching Frequency(Min)360 kHz
ТипConverter
Vin(Max)3 В
Vin(Min)0.8 В
Vout(Max)3 В
Vout(Min)3 В
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: TPS61005 (4)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS61005DGSRG4
