Datasheet Texas Instruments SN74LVCH16652ADGVR — Даташит
Серия | SN74LVCH16652A |
Модель | SN74LVCH16652ADGVR |
16-битный шинный приемопередатчик и регистр с выходами с 3 состояниями 56-TVSOP от -40 до 125
SN74LVCH16652A 16-Bit Bus Transceiver and Register with 3-State Outputs datasheet
PDF, 1.1 Мб, Версия: J, Файл опубликован: 27 дек 2014
Pin | 56 |
Package Type | DGV |
Industry STD Term | TVSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | LDH652A |
Width (мм) | 4.4 |
Length (мм) | 11.3 |
Thickness (мм) | 1.05 |
Pitch (мм) | .4 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Bits | 16 |
F @ Nom Voltage(Max) | 100 Mhz |
ICC @ Nom Voltage(Max) | 0.02 мА |
Output Drive (IOL/IOH)(Max) | -24/24 мА |
Package Group | TVSOP |
Package Size: mm2:W x L | 56TVSOP: 72 mm2: 6.4 x 11.3(TVSOP) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LVC |
VCC(Max) | 3.6 В |
VCC(Min) | 1.65 В |
Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
tpd @ Nom Voltage(Max) | 6.4,6.3 нс |
- Bus-Hold CircuitPDF, 418 Кб, Файл опубликован: 5 фев 2001
When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
Серия: SN74LVCH16652A (4)
- SN74LVCH16652ADGGR SN74LVCH16652ADGVR SN74LVCH16652ADL SN74LVCH16652ADLG4
- Semiconductors > Logic > Buffer/Driver/Transceiver > Registered Transceiver
