Datasheet Texas Instruments ADS7869IPZTRG4 — Даташит
СерияADS7869
МодельADS7869IPZTRG4
12 каналов, 7 одновременных выборок, аналоговый интерфейс управления двигателем с 3 1MSPS, 12-разрядные АЦП 100-TQFP от -40 до 85
Analog Motor Control Front-End with Simultaneous Sampling on Seven datasheet
PDF, 1.3 Мб, Версия: E, Файл опубликован: 25 июл 2006
Pin100
Package TypePZT
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Package QTY1000
МаркировкаADS7869I
Width (мм)14
Length (мм)14
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
# Input Channels12
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)4.5 В
АрхитектураSAR
Digital Supply(Max)5.5 В
Digital Supply(Min)2.7 В
INL(Max)2.5 +/-LSB
Input Range(Max)2.5 В
Input Range(Min)-2.5 В
Тип входаDifferential
Integrated FeaturesN/A
InterfaceParallel,SPI
Multi-Channel ConfigurationSimultaneous Sampling
Package GroupTQFP
Package Size: mm2:W x L100TQFP: 256 mm2: 16 x 16(TQFP) PKG
Power Consumption(Typ)250 mW
Reference ModeExt,Int
Разрешение12 Bits
SINADN/A дБ
SNR71 дБ
Sample Rate (max)1MSPS SPS
Sample Rate(Max)1 MSPS
THD(Typ)-78 дБ
  • Using the ADS7869 Reference Design Evaluation Module
    PDF, 205 Кб, Файл опубликован: 26 окт 2005
    This application report describes the characteristics, operation, and use of the ADS7869 for the Motor Control Demo Board. This board is used as part of the demonstration materials for the Digital Motor Control Seminar presented by Texas Instruments. A complete circuit description and schematic diagram are included.
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS7869 (4)
На английском языке: Datasheet Texas Instruments ADS7869IPZTRG4
