Datasheet Texas Instruments 5962-8861901YA — Даташит
СерияSMJ320C25
Модель5962-8861901YA
Процессоры цифровых сигналов 68-LCCC от -55 до 125
SMJ320C25, SMJ320C25-50 Digital Signal Processors datasheet
PDF, 738 Кб, Версия: D, Файл опубликован: 31 окт 2001
Pin68
Package TypeFD
Industry STD TermLCCC
JEDEC CodeS-CQCC-N
Package QTY1
CarrierJEDEC TRAY (10+1)
Width (мм)24.11
Length (мм)24.11
Thickness (мм)2.57
Max Height (мм)3.05
Cycle Time100 нс
DMAExt Ch
Data / Program Memory Space64K/64K Words
Тактовая частота40 МГц
MIPS10
MOPS60
Package GroupLCCC
Pin/Package68CPGA, 68JLCC, 68LCCC
RatingMilitary
RoHSSee ti.com
  • Setting Up TMS320 DSP Interrupts in 'C'
    PDF, 168 Кб, Файл опубликован: 1 ноя 1994
    Four steps are required to set the TMS320 DSP interrupts: create a interrupt service routine initialize the vector table and set the memory map enable the interrupts in the CPU and enable the interrupt sources. This document shows how to set the interrupts in C C callable assembly or in-line C. Sample C code segments are provided. The appendix gives complete examples for setting interrupt vec
  • Minimizing Quantization Effects Using the TMS320 DSP Family
    PDF, 268 Кб, Файл опубликован: 1 июл 1994
    Due to its discrete nature DSPs represent variables and performs arithmetic functions with a finite word length. This produces three effects: the selection of filter transfer functions is quantized with filter poles and zeros existing only at specific locations in the z plane; the input is quantized; and noise is introduced from DSP multiplication and division operations. This document shows how
  • Engine Knock Detection Using Spectral Analysis With TMS320C25 or TMS320C30 DSPs
    PDF, 254 Кб, Файл опубликован: 1 янв 1995
    An efficient method of detecting combustion engine knock is using spectral analysis. The detection process algorithm adapts to a no-knock reference at varying speeds and loads by using multiple frequencies. This document presents an problem overview current technology and two implementation examples are given to aid in the development of system specific hardware and software. The first system is
  • Semiconductors > Processors > Digital Signal Processors > Other High Reliability DSPs
59628861901YA, 5962 8861901YA
На английском языке: Datasheet Texas Instruments 5962-8861901YA
