Datasheet Texas Instruments TPS76925DBVRG4 — Даташит
СерияTPS769
МодельTPS76925DBVRG4
Линейный регулятор 10 В, 100 мА, низкий Iq, с малым падением напряжения 5-SOT-23 от -40 до 125
Ultra Low-Power 100-mA Low-Dropout Line Regulators datasheet
PDF, 888 Кб, Версия: E, Файл опубликован: 10 янв 2002
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY3000
МаркировкаPCJI
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Точность3 %
Fixed Output Options1.2,1.5,1.8,2.5,2.7,2.8,3,3.3,5 В
Iout(Max)0.1 A
Iq(Typ)0.017 мА
Noise190 uVrms
PSRR @ 100KHz27 дБ
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Regulated Outputs1
Special FeaturesEnable
Thermal Resistance ОёJA180 В°C/W
Vdo(Typ)71 мВ
Vin(Max)10 В
Vin(Min)2.7 В
Vout(Max)5.5 В
Vout(Min)1.2 В
  • Evaluation Modules & Boards: TPS76933EVM-127
    SOT23 LDO, 5 V to 1.0 V, 100mA output power supply
  • Evaluation Modules & Boards: TPS76901EVM-127
    SOT23 LDO, 5 V to 1.8 V, 100mA output power supply
  • Evaluation Modules & Boards: DEM-SOT23LDO
    DEM-SOT23LDO Compatible With Most Positive-Output LDO Regulators in 5- or 6-Lead SOT23 (DBV) Package
  • Evaluation Modules & Boards: TMDXEVM388
    DM388 DaVinci Digital Media Processor Evaluation Module
  • Powering the TMS320VC5402 DSP Using the TPS60100, TPS76918, and the TPS3305-18
    PDF, 61 Кб, Файл опубликован: 16 дек 1999
    This report analyzes a low-cost, low-power supply design utilizing the TPS60100 dc-to-dc converter, the TPS76918 series regulator, and the TPS3305-18 power-supply supervisor to power DSP applications.
  • Optical Implementation Using IEEE-1394.b (Rev. A)
    PDF, 133 Кб, Версия: A, Файл опубликован: 1 мар 2004
    IEEE Std 1394b-2002 specification allows the use of optical media for longer distances at higher speeds. The use of optical media provides galvanic isolation, lower electromagnetic interference (EMI), and lower interference from the environment.Interfacing 1394.b physical-layer devices (PHYs) may require additional components, depending on the type of fiber-optic transceiver (FOT) selected. Th
  • Ceramic Capacitors Replace Tantalum Capacitors in LDOs (Rev. A)
    PDF, 44 Кб, Версия: A, Файл опубликован: 13 окт 2006
    With the proper considerations ceramic output capacitors can be used with low dropout regulators (LDO) and DC/DC switching converters that require tantulum output capacitors.
  • Selecting the correct IC for power-supply applications
    PDF, 184 Кб, Файл опубликован: 14 дек 2006
На английском языке: Datasheet Texas Instruments TPS76925DBVRG4
