Datasheet Texas Instruments TMS320VC5470GHKA — Даташит
СерияTMS320VC5470
МодельTMS320VC5470GHKA
Процессор цифровых сигналов системного уровня 257-BGA MICROSTAR
TMS320VC5470 Fixed-Point Digital Signal Processor datasheet
PDF, 675 Кб, Версия: B, Файл опубликован: 9 дек 2002
Цифровой сигнальный процессор DSP, DSP Fixed-Point 16Bit 100MHz 257Pin BGA MICROSTAR
TMS320VC5470GHKA
454 ₽
TMS320VC5470GHKA
TMS320VC5470GHKA
TMS320VC5470GHKA
Pin257257
Package TypeGHKGHK
Industry STD TermBGA MICROSTARBGA MICROSTAR
JEDEC CodeS-PBGA-NS-PBGA-N
Маркировка320VC5470GHKATMS
Width (мм)1616
Length (мм)1616
Thickness (мм).9.9
Pitch (мм).8.8
Max Height (мм)1.41.4
RoHSНе совместим
  • TMS320VC5470/5471 Bootloader
    PDF, 147 Кб, Файл опубликован: 10 июн 2002
    The TMS320VC547x devices, TMS320VC5470 and TMS320VC5471, have a master TMS470R1xв„ў (ARM7TDMIE) microcontroller (MCU) central processing unit (CPU) with a slave TMS320C54xв„ў digital signal processor (DSP) CPU. Bootload is accomplished through the MCU while the DSP is held in reset. Since no ROM resides on these devices, the bootloader code is transferred on-chip through one of several int
  • TMS320VC5471/TMS320VC5470 Inter-Processor Communication
    PDF, 138 Кб, Файл опубликован: 10 июн 2002
    The TMS320VC547x (VC547x) generation of devices, including the TMS320VC5470 and the TMS320VC5471, has a master TMS470R1x (ARM7TDMIE) microcontroller unit (MCU) CPU with a slave TMS320C54xв„ў (C54xв„ў) digital signal processor (DSP) CPU. Inter-processor communication (IPC) between the two processors can be performed using various methods. This document describes an interrupt-driven method o
  • Using Boundary Scan on the TMS320VC5471/VC5470 DSPs
    PDF, 61 Кб, Файл опубликован: 15 апр 2002
    The Texas Instruments (TI) TMS320VC5471 and TMS320VC5470 DSPs (hereafter referred to as VC547x) are dual-core processor devices implementing standard IEEE 1149.1 boundary scan capability. This application report contains a description of the VC547x boundary scan implementation and information about how to use it with other boundary scan tools and devices.The material covered in this applicatio
Серия: TMS320VC5470 (3)
  • Semiconductors > Processors > Digital Signal Processors > C5000 DSP > Other C5000 DSP
На английском языке: Datasheet Texas Instruments TMS320VC5470GHKA
