Datasheet Texas Instruments SN74LVC00AMPWREPG4 — Даташит
СерияSN74LVC00A-EP
МодельSN74LVC00AMPWREPG4
Усовершенствованный продукт, четверной, с 2 входами, положительный логический элемент NAND, 14-TSSOP, от -55 до 125
SN74LVC00A-EP datasheet
PDF, 557 Кб, Версия: B, Файл опубликован: 3 июл 2006
7 предложений от 7 поставщиков
Микросхема Логический чип, NAND Gate 4Element 2IN CMOS 14Pin TSSOP T/R
SN74LVC00AMPWREPG4
16 ₽
SN74LVC00AMPWREPG4
26 ₽
SN74LVC00AMPWREPG4
SN74LVC00AMPWREPG4
Pin14
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаLVC00AM
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
F @ Nom Voltage(Max)150 Mhz
ICC @ Nom Voltage(Max)0.01 мА
Тип входаTTL
Рабочий диапазон температурот -40 до 125,-55 до 125 C
Output Drive (IOL/IOH)(Max)24/-24 мА
Тип выходаTTL
Package GroupTSSOP
Package Size: mm2:W x L14TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
RatingHiRel Enhanced Product
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)2 В
tpd @ Nom Voltage(Max)5.1,4.3 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Space & High Reliability > Logic Products > Gate Products
На английском языке: Datasheet Texas Instruments SN74LVC00AMPWREPG4
Публикации по теме
