Datasheet Texas Instruments DRV8332DKD — Даташит
| Серия | DRV8332 |
| Модель | DRV8332DKD |
Драйвер трехфазного бесщеточного двигателя постоянного тока 13 А с защитой от бросков тока (PWM Ctrl) 36-HSSOP от -40 до 85
DRV83x2 Three-Phase PWM Motor Driver datasheet
PDF, 2.5 Мб, Версия: E, Файл опубликован: 31 дек 2014
Купить DRV8332DKD на РадиоЛоцман.Цены — от 198 до 2 378 ₽31 предложений от 18 поставщиков IC BRIDGE DRIVER PAR 36HSSOP. Half Bridge (3) Driver DC Motors, General Purpose Power MOSFET 36-HSSOP. PMIC - Full, Half-Bridge Drivers... | |||
| DRV8332DKD Texas Instruments | 943 ₽ | ||
| DRV8332DKD Texas Instruments | 1 325 ₽ | ||
| DRV8332DKD Texas Instruments | по запросу | ||
| Pin | 36 |
| Package Type | DKD |
| Industry STD Term | HSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 29 |
| Carrier | TUBE |
| Маркировка | DRV8332 |
| Width (мм) | 11 |
| Length (мм) | 15.9 |
| Thickness (мм) | 3.5 |
| Pitch (мм) | .65 |
| Max Height (мм) | 3.6 |
| Mechanical Data | Скачать |
| Control I/F | PWM (3x) |
| Number of Half Bridges | 3 |
| Package Group | HSSOP |
| Peak Output Current | 13 A |
| RDS(ON) (HS + LS) | 220 mOhms |
| RMS Output Current | 8 A |
| Rating | Catalog |
| Vs(Max) | 52.5 В |
- Hardware Design Considerations for an Electric Bicycle using BLDC MotorPDF, 530 Кб, Файл опубликован: 11 июн 2014
A traditional bicycle is a two-wheel vehicle that is propelled by the rider who delivers muscle power through pedals that rotate one of the two wheels. The rider steers the front wheel to create a force that returns and maintains the vehicle center of gravity into a stable zone whenever necessary, thus keeping the bicycle upright. An electric bicycle carries batteries that deliver electric power t - Hardware Design Considerations for an Efficient Vacuum Cleaner using BLDC Motor (Rev. A)PDF, 213 Кб, Версия: A, Файл опубликован: 15 июл 2015
A vacuum cleaner is a device that uses an air pump to create a partial vacuum to suck up dirt and dust particles from a given surface. Vacuum cleaners are used in homes as well as in industries and come with a variety of power levels, small battery-operated hand-held devices, domestic central vacuum cleaners and huge stationary industrial appliances. A universal motor is typically used as suction - Sensored 3-Phase BLDC Motor Control Using MSP430PDF, 199 Кб, Файл опубликован: 20 июл 2011
Brushless DC (BLDC) motors are electronically commutated motors that offer many advantages over brushed DC motors and, therefore, are becoming very popular industrially and commercially. This application report discusses a sensored 3-phase BLDC motor control solution using MSP430в„ў as the motor controller. Hall sensors are used to detect the rotor position and close the commutation loop. Both open
Серия: DRV8332 (2)
- DRV8332DKD DRV8332DKDR
- Semiconductors > Motor Drivers > Brushless DC (BLDC) Drivers > Brushless DC Drivers with FETs
