Datasheet ТI ADS8326IDGKT — Даташит
| Серия | ADS8326 |
| Модель | ADS8326IDGKT |
16-разрядный псевдодифференциальный вход, последовательный выход 250 кс/с, микросхема АЦП от 2,7 В до 5,5 В, 8-VSSOP от -40 до 85
16-Bit, High-Speed, 2.7V to 5V, microPower Sampling Analog-to-Digital Converter datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 30 сен 2009
- The IBIS model, Part 3: Using IBIS models to investigate signal-integrity issuesPDF, 265 Кб, Файл опубликован: 17 июн 2011
- 2Q 2011 Issue Analog Applications JournalPDF, 2.0 Мб, Файл опубликован: 17 июн 2011
- Interfacing the MSOP8EVM to TMS470 ProcessorsPDF, 68 Кб, Файл опубликован: 15 мар 2006
This application report presents a method for interfacing the modular MSOP8EVM, an evaluation module (EVM) for single-channel, low-power, 8- to 16-bit serial analog-to-digital converters to the TMS470 series microcontrollers. The hardware used for this example includes the TMS470 Kickstart Development Kit evaluation kit featuring the 60-MHz TMS470R1B1M and the HPA-MCU Interface Board. The soft - Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
The input structure circuit of a successive-approximation register analog-to-digital converter (SAR ADC) incombination with the driving circuit forms a transfer function that can be used to determine minimum acquisition times for different types of applied input signals. This application report, which builds on Determining Minimum Acquisition Times for SAR ADCs When a Step Function is Applied to - Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference. - Principles of Data Acquisition and Conversion (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS8326 (11)
