Datasheet Texas Instruments 74LVC1G125DCKRG4 — Даташит
СерияSN74LVC1G125
Модель74LVC1G125DCKRG4
Буферный вентиль с одной шиной и выходами с 3 состояниями 5-SC70 от -40 до 125
SN74LVC1G125 Single Bus Buffer Gate With 3-State Output datasheet
PDF, 1.5 Мб, Версия: T, Файл опубликован: 21 окт 2014
Pin55555
Package TypeDCKDCKDCKDCKDCK
Industry STD TermSOT-SC70SOT-SC70SOT-SC70SOT-SC70SOT-SC70
JEDEC CodeR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-G
Package QTY30003000300030003000
CarrierLARGE T&RLARGE T&RLARGE T&RLARGE T&RLARGE T&R
МаркировкаCM5CMKCMFCMTCMR
Width (мм)1.251.251.251.251.25
Length (мм)22222
Thickness (мм).9.9.9.9.9
Pitch (мм).65.65.65.65.65
Max Height (мм)1.11.11.11.11.1
Mechanical DataСкачатьСкачатьСкачатьСкачатьСкачать
3-State OutputYes
Bits1
F @ Nom Voltage(Max)150 Mhz
Gate TypeBUFFER
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)32/-32 мА
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
Schmitt TriggerNo
Special FeaturesIoff,down translation to Vcc,low power,3-state
Sub-FamilyNon-Inverting Buffer/Driver
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,3.3,5 В
tpd @ Nom Voltage(Max)9,5.5,4.5,4 нс
  • Evaluation Modules & Boards: TAS5722LEVM
    TAS5722L Digital Input Mono Class-D Audio Amplifier Evaluation Module
  • Evaluation Modules & Boards: TAS2557EVM
    TAS2557 5.7-W Class-D Audio Amplifier Evaluation Module with Class-H Boost and Speaker Sense
  • Evaluation Modules & Boards: TAS2560EVM
    TAS2560 5.6W Class-D Audio Amplifier Evaluation Module
  • Evaluation Modules & Boards: TMDXEVM388
    DM388 DaVinci Digital Media Processor Evaluation Module
  • Evaluation Modules & Boards: PP-SALB2-EVM
    Smart Amplifier Speaker Characterization Board Evaluation Module
  • Evaluation Modules & Boards: DLPLCR4500EVM
    DLPВ® LightCrafterВ™ 4500
  • Evaluation Modules & Boards: EVMX777BG-01-00-00
    J6Entry, RSP and TDA2E-17 CPU Board Evaluation Module
  • Evaluation Modules & Boards: EVMX777G-01-20-00
    J6Entry/RSP Infotainment (CPU+Display+JAMR3) Evaluation Module
  • Evaluation Modules & Boards: TAS2559EVM
    TAS2559 5.7-W Class-D Audio Amplifier Evaluation Module
  • Designing and Manufacturing with TI's X2SON Packages
    PDF, 134 Кб, Файл опубликован: 23 авг 2017
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Migration From 3.3-V To 2.5-V Power Supplies For Logic Devices
    PDF, 115 Кб, Файл опубликован: 1 дек 1997
    This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
  • Live Insertion
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments 74LVC1G125DCKRG4
