Datasheet ТI OPA2677U/2K5 — Даташит
| Серия | OPA2677 |
| Модель | OPA2677U/2K5 |
Двойной широкополосный операционный усилитель SpeedPlus™ с высоким выходным током 8-SOIC от -40 до 85
Dual, Wideband, High Output Current Operational Amplifier datasheet
PDF, 1.4 Мб, Версия: I, Файл опубликован: 2 июл 2008
- Measuring Board Parasitics in High-Speed Analog DesignPDF, 134 Кб, Файл опубликован: 7 июл 2003
Successful circuit designs using high-speed amplifiers can depend upon understanding and identifying parasitic PCB components. Simulating a design while including PCB parasitics can protect against unpleasant production surprises. This application report discusses an easy method for measuring parasitic components in a prototype or final PC board design by using a standard oscilloscope and low freq - Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Active filters using current-feedback amplifiersPDF, 227 Кб, Файл опубликован: 25 фев 2005
- Expanding the usability of current-feedback amplifiersPDF, 215 Кб, Файл опубликован: 28 фев 2005
- Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Current Feedback Amplifiers: Review, Stability Analysis, and ApplicationsPDF, 53 Кб, Файл опубликован: 20 ноя 2000
The majority of op amp circuits are closed-loop feedback systems that implement classical control theory analysis. Analog designers are comfortable with Voltage FeedBack (VFB) op amps in a closed-loop system and are familiar with the ideal op amp approximations feedback permit. This application bulletin will demonstrate how CFB op amps can be analyzed in a similar fashion. Once the closed-loop sim - Noise Analysis for High Speed Op Amps (Rev. A)PDF, 256 Кб, Версия: A, Файл опубликован: 17 янв 2005
As system bandwidths have increased an accurate estimate of the noise contribution for each element in the signal channel has become increasingly important. Many designers are not however particularly comfortable with the calculations required to predict the total noise for an op amp or in the conversions between the different descriptions of noise. Considerable inconsistency between manufactu - Wireline Data Transmission and ReceptionPDF, 191 Кб, Файл опубликован: 27 янв 2010
Many types of wires are widely used to transmit data. Specifically, Category 3 and Category 5 (Cat3 and Cat5e, respectively)—also known as unshielded twisted pair or UTP lines—are now recommended for new telephone installations. Coaxial (coax) cables are used to distribute cable television (CATV) signals throughout a home. #12 and #14 American wire gauge (AWG) electric power distribution wire is a - Stabilizing Current-Feedback Op Amps While Optimizing Circuit PerformancePDF, 280 Кб, Файл опубликован: 28 апр 2004
Optimizing a circuit design with a current-feedback (CFB) op amp is a relatively straightforward task, once one understands how CFB op amps achieve stability. This application note explains a 2nd-order CFB model so that any designer can better understand the flexibility of the CFB op amp. This report also discusses stability analysis, the effects of parasitic components due to PCBs, optimization - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2677 (14)
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > High-Speed Op Amps (>=50MHz)
