Datasheet Texas Instruments SN74LVC139AD — Даташит
СерияSN74LVC139A
МодельSN74LVC139AD
Двойной 2-4-строчный декодер/демультиплексор 16-SOIC от -40 до 85
SN74LVC139A datasheet
PDF, 1.1 Мб, Версия: O, Файл опубликован: 2 окт 2003
Pin16
Package TypeD
Package QTY40
МаркировкаLVC139A
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
Полоса частот100 МГц
Bits4
Количество каналов2
Configuration2:4
Digital input leakage(Max)5 uA
ESD Charged Device Model0.75 kV
ESD HBM2 kV
F @ Nom Voltage(Max)100 Mhz
FunctionDecoder/Demultiplexer
ICC @ Nom Voltage(Max)0.01 мА
Output Drive (IOL/IOH)(Max)24/-24 мА
Schmitt TriggerNo
Technology FamilyLVC
ТипStandard
VCC(Max)3.6 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)20.6,9.3,7.3,6.2 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Switches and Multiplexers > Buffered Encoders and Decoders
На английском языке: Datasheet Texas Instruments SN74LVC139AD
