Datasheet Texas Instruments SN74CB3T3306DCTR — Даташит
СерияSN74CB3T3306
МодельSN74CB3T3306DCTR
Транслятор напряжения двухшинного переключателя 8-SM8 от -40 до 85
SN74CB3T3306 Dual FET Bus Switch 2.5-V/3.3-V Low-Voltage Bus Switch With 5-V Tolerant Level Shifter datasheet
PDF, 895 Кб, Версия: C, Файл опубликован: 31 дек 2015
Pin88
Package TypeDCTDCT
Industry STD TermSSOPSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY30003000
CarrierLARGE T&RLARGE T&R
МаркировкаWA6Z
Width (мм)2.82.8
Length (мм)2.952.95
Thickness (мм)1.291.29
Pitch (мм).65.65
Max Height (мм)1.31.3
Additional FeaturesPowered off protection,Signal path Translation
Полоса частот100 МГц
Configuration1:1 SPST
ESD Charged Device Model1 kV
ESD HBM2 kV
Input/Ouput Voltage(Max)5.5 В
Input/Output Continuous Current(Max)128 мА
Input/Output OFF-state Capacitance(Typ)4.5 пФ
Input/Output ON-state Capacitance(Typ)4 пФ
Количество каналов2
OFF-state leakage current(Max)10 мкА
Package GroupSM8
Package Size: mm2:W x L8SM8: 12 mm2: 4 x 2.95(SM8) PKG
Ron(Max)8 Ohms
Ron(Typ)5 Ohms
Supply Current(Max)20 uA
Supply Range3.6 Max
VIH(Min)1.7 В
VIL(Max)0.8 В
Vdd(Max)3.6 В
Vdd(Min)2.3 В
Vss(Max)N/A В
Vss(Min)N/A В
  • CBT-C, CB3T, and CB3Q Signal-Switch Families
    PDF, 584 Кб, Файл опубликован: 4 фев 2003
    Signal switch devices are widely used in applications requiring bus isolation, multiplexing, demultiplexing, and voltage translation. Compared to other logic and linear product alternatives, signal switches are the fastest and least power consuming. Texas Instruments (TI) CBT-C, CB3Q, and CB3T signal-switch families have low on-state resistance, negligible power consumption, and better undershoot
На английском языке: Datasheet Texas Instruments SN74CB3T3306DCTR
