Datasheet ТI TLV1578CDARG4 — Даташит
| Серия | TLV1578 |
| Модель | TLV1578CDARG4 |
8-гл.
2.7 V to 5.5 V, 1-/-8 Channel 10-Bit Parallel Analog-to-Digital Converters datasheet
PDF, 627 Кб, Версия: D, Файл опубликован: 11 июл 2000
10-битный АЦП, 1,25 MSPS, 8-канальный, DSP/SPI, аппаратно настраиваемый, малое энергопотребление 32-TSSOP от 0 до 70
- Interfacing the TLV1571/78 Analog-to-Digital Converter to the TMS320C542 DSPPDF, 192 Кб, Файл опубликован: 7 окт 1999
This application report presents a hardware solution for interfacing the TLV1571/TLV1578 10-bit, 1.25 MSPS low-power analog-to-digital converter (ADC) to the 16-bit fixed-point TMS320C542 digital signal processor (DSP). The report describes the interface hardware and C-callable software routines, which support communication between ADC and DSP. - Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
Серия: TLV1578 (6)
- TLV1578CDA TLV1578CDAG4 TLV1578CDAR TLV1578CDARG4 TLV1578IDA TLV1578IDAG4
