Datasheet Texas Instruments UC29432DG4 — Даташит
| Серия | UC29432 |
| Модель | UC29432DG4 |
Прецизионный аналоговый контроллер 8-SOIC от -25 до 85
Precision Analog Controller datasheet
PDF, 1.9 Мб, Версия: A, Файл опубликован: 5 дек 2008
Купить UC29432DG4 на РадиоЛоцман.Цены — от 320 до 2 558 ₽13 предложений от 13 поставщиков IC PREC ANALOG CONTROLLER 8SOIC. Overvoltage Comparator, Optocoupler PMIC 8-SOIC. PMIC - Power Management - Specialized | |||
| UC29432DG4 Texas Instruments | 320 ₽ | ||
| UC29432DG4 Texas Instruments | 424 ₽ | ||
| UC29432DG4 Rochester Electronics | 612 ₽ | ||
| UC29432DG4 Texas Instruments | 872 ₽ | ||
| Pin | 8 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 75 |
| Carrier | TUBE |
| Маркировка | UC29432 |
| Width (мм) | 3.91 |
| Length (мм) | 4.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| On Board Oscillator | N/A |
| On Board Reference | 1.3 |
| Operating Supply Current | 0.5 мА |
| Operating Supply(Max) | 36 В |
| Operating Supply(Min) | 2.2 В |
| Рабочий диапазон температур | от -25 до 85 C |
| Выходной ток | 0.1 A |
| Package Group | SOIC |
| Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
| Rating | Catalog |
| Reference Voltage | 1.3 В |
| Vref tol | 0.8 % |
- DN-52 Adjustable Electronic Load for Low Voltage DC ApplicationsPDF, 137 Кб, Файл опубликован: 5 сен 1999
Testing power supply regulation over a specified output current range is greatly simplified with the use of an adjustable electronic load. Load current can be varied from zero to the full rated value with the twist of a panel-mounted potentiometer or by a digital interface. This design note describes a design using the UC39432 in a self-biased, constant-current adjustable electronic load that is f
Серия: UC29432 (4)
- UC29432D UC29432DG4 UC29432N UC29432NG4
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Feedback Signal Generator
