Datasheet Texas Instruments VCA2618YT — Даташит
СерияVCA2618
МодельVCA2618YT
Двойной усилитель с переменным коэффициентом усиления и входным буфером 32-TQFP от -40 до 85
VCA2618: Dual, Variable Gain Amplifier with Input Buffer datasheet
PDF, 753 Кб, Версия: B, Файл опубликован: 6 ноя 2003
Pin32
Package TypePBS
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Package QTY250
CarrierSMALL T&R
Маркировка2618Y
Width (мм)5
Length (мм)5
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Acl, min spec gain1.25 V/V
BW @ Acl30 МГц
Max Gain45 дБ
Количество каналов2
PGA/VGAVGA
Package GroupTQFP
Package Size: mm2:W x L32TQFP: 49 mm2: 7 x 7(TQFP) PKG
Slew Rate(Typ)300 V/us
Vs(Max)5.25 В
Vs(Min)4.75 В
  • Evaluation Modules & Boards: VCA2619EVM
    VCA2619 Evaluation Module
  • AB-170: Ultrasound Processor Supplementary Material
    PDF, 752 Кб, Файл опубликован: 25 янв 2001
    An ultrasound system employs a multichannel phased array of acoustic elements to form an image. Previous implementation of this function has used bipolar technology. 0.5u CMOS technology has the advantage of lowering the cost and increasing functionality compared to using bipolar technology.
  • Dual-Channel VCAs: Methods for Powering Down One Channel
    PDF, 102 Кб, Файл опубликован: 11 июн 2004
    Texas Instruments offers several product groups of highly-integrated voltage-controlled amplifiers (VCAs) including the VCA2611/12/13/16 and the VCA2614/18/19. Both the VCA2611 and the VCA2614 families feature two channels, either of which can be powered while powering down the other. This application note outlines two possible approaches to this question and describes the steps needed to assure t
Серия: VCA2618 (1)
  • VCA2618YT
  • Semiconductors > Amplifiers > Programmable & Variable Gain Amplifiers (PGA/VGA)
На английском языке: Datasheet Texas Instruments VCA2618YT
